Working on a 95 F250 to do the balljoints but can't get the hubs out. Took the dust cap off, the retaining clip and am at the point where it should just "slide out" but it ain't movin. Barely any movement in or out. Help!!!
Reason: Spelling
Good call. Completely forgot about that one. Got it goin now. Now I can't get the driver side spindle to separate from the knuckle. Pass side came off but this one ain't budgin. Any ideas?
Bfh lol. That's how mine were. On one side the ball joints were bad and the slop freed up the knuckle but the other side they were still ok so it was a major pain to get off. You could try heating it up and using pb blaster but be careful because the grease and brake lines
Been trying the bfh with no luck. Sprayed the crap out of it with on blaster and gonna let it sit overnight. Gonna try the pneumatic hammer tomorrow too.
The proper tool for that is a thing that screws on to the spindle with one end and onto a slide hammer on the other. If you try beating it with a hammer or taking it off with a chisel then you will ruin it. Napa sells that tool. It's a universal spindle puller.
Meineke told this guy that his drag link and tie rod needed to be replaced. How often does this occur? I can understand changing the joints where they attach to the knuckle and but I'm not so sure about changing out the drag link and tie rod. Thoughts?
The drag link is about the most common one of them to go bad in my experience. Which is mostly alignments and abs systems on Fords. I wouldn't let meineke do it though. They are way over priced. They are also flat rate everywhere I know. That means it's possible they look for crap that is wrong.
Just check them yourself. With the engine off have someone else wiggle the steering wheel while you watch the joints. If they move, they are bad.
It seems that the passenger side ball joints are always the ones to go bad (maybe hits more potholes etc). I just replaced the pass side a long time ago and keep checking the drivers side.
So the actual drag link goes bad or just the joints? We're doing it instead of meineke. I just don't want to have to replace what's basically just a metal bar if only the joints need it unless the joints aren't removable and u have to replace the whole thing as a whole. The passenger side hub body is also destroyed. The outer part of the body is ripped away from the inner part that slides onto the axle shaft. Anyone know where we can get a new hub body?
The drag link has one joint on it that doesn't come off. The one on the pitman arm end usually. Unless you got a chevy or a D 60! It connects the pitman arm to the right steering knuckle/ tie rod end. The adjuster on it is what you use to center your steering wheel on a dana 60. On the F250 you set toe on each wheel and they control the wheel centering. So you will need to get the toe set once you replace it again. Make sure you tell them JUST A TOE ALIGN. It's cheaper according to flat rate manuals and shops will not tell you this.
Got the spindles off, axles out, balljoints replaced and am now waiting on ujoints. The ones on the axles were trashed! 2 of the 4 cups on the ujoints didnt have any needle bearings inside anymore.
