Spark Plug Wire Seperators
Old Dec 9, 2010 | 08:46 AM
kcb37's Avatar
kcb37
I am helping a friend fix up his truck some. In the past we had re-routed the plug wires due to the arcing some of these experiance. It ran much better, but it is now in need of new ones. I am going to put some Ford Racing Wires on it, but I would like new seperators that perferably are a clamp style. Problem is I am not having much luck finding any and am quickly running out of time to look.
If any of you have suggestions I would appreciate the help.
The truck is a 94 F-150, 5.0
Old Dec 9, 2010 | 11:02 AM
redlightning93's Avatar
redlightning93
Try Summit Racing
Old Dec 9, 2010 | 12:27 PM
oleman's Avatar
oleman
LMC truck has them.
Old Dec 10, 2010 | 06:00 AM
TexasGuy001's Avatar
TexasGuy001
I would NOT put the Ford Racing wires on it. They are way too long and don't fit well. They also don't have the right coil wire, so you can't use the clip that holds it on. Just get some Motorcraft ones from Summit or some BWD ones from Orielly. The factory type spark plug wire seperators are available in the HELP section at most stores. These wr4093 should be what you need. I just put some on my truck.
http://www.summitracing.com/search/?...d=wr4093&dds=1
