Need some honest advise
Old Dec 9, 2010 | 12:10 AM
Restor56's Avatar
Restor56
Question Need some honest advise
I am thinking about buying a 1996 f150 4x4 auto tranny Overdrive the truck has a 5.0 efi in it and the guy says that the tranny would not shift from 3rd or would not go above 50 either now i found a 1988 full size bronco tranny 4x4 but it says nothing about this overdrive crap will this make a problem if i put this tranny into this 150 or can i just make it a 2wd truck? and how hard will it be for me to do the swap?
Old Dec 9, 2010 | 01:09 AM
TexasGuy001's Avatar
TexasGuy001
Does the 96 have an E40D or 4R70W? What transmission is in the 88?
Old Dec 9, 2010 | 09:27 AM
Restor56's Avatar
Restor56
the 88 it's a C6 and i am finding out what type is in the 96
Old Dec 9, 2010 | 12:32 PM
oleman's Avatar
oleman
Swap in the c6 and the transfer case.
Then trick the computer into running the engine correctly. It also uses feed-back from the tranny for engine control.
The C6 is a much easier tranny to work with than the new stuff and much more heavy duty.
