bendix staying engaged
Old Dec 8, 2010 | 07:42 PM
johnsteffy's Avatar
johnsteffy
hello everybody. alright so on my 95 psd, this morning i went out to start my truck, was late for work didnt get to plug it in, uit was probably about 20 out. i let the glowplugs light for a lot longer then usually, crank it once, almost starts. so i just hit it real quick to get it too start, and the starter stayed engaged until i could get the battery disconnected. i hooked the batteries back up, went to start it again and the starter got stuck engaged again. now the starter is stucked engaged once the truck gets any power, even without me touching the key. any ideas? thanks alot in advance
Old Dec 8, 2010 | 07:49 PM
pjwoolw's Avatar
pjwoolw
Check the starter relay on the passenger side of the engine compartment. Disconnect the lead to the starter motor. You'll need some sort of volt meter. Then with the key on see if you have 12 volts on that side of the relay to ground. If so there is your problem. The relay. The starter should only work when the relay is engaged.
Old Dec 9, 2010 | 07:01 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
I've had 2 trucks do the same thing, but the batteries were so low they would not disengage the starter. Sounds weird but it's true. Fresh batteries fixed it.
Also something to consider.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
ZombieJames
1997 - 2003 F150
Aug 16, 2016 12:11 AM
Roswell
Georgia Chapter
Feb 10, 2016 08:08 AM
1975FordF250
May 17, 2014 09:32 AM
cgi2099
Jan 13, 2012 07:39 PM
littledonko
Feb 11, 2010 11:11 AM
