Stupid question ?
Old Dec 8, 2010 | 01:23 PM
MohaveMan's Avatar
MohaveMan
Stupid question ?
I have a 1984 F-150 w/ AOD. My question is which gear is the best for city/town driving ? This is my first overdrive tranny and I do not know which to select. Do I use the first D encircled in white or do I use the next selection of a plain D ? I know that the third D is low gear and used only when pulling a giant grade or for heavy towing. Sorry this seems so simple but quite frustrating when you don't know. Any and all responses will be greatly appreciated. At present I use the D encircled in white but am not sure if this is correct.
Old Dec 8, 2010 | 02:36 PM
k_nine's Avatar
k_nine
i aways drive in overdrive unless it keeps switching in and out the i will use drive.
Old Dec 8, 2010 | 02:48 PM
TheKirbyMan's Avatar
TheKirbyMan
I don't know much about the AOD but I'll do what I can...
On the gear indicator, what are the letters and/or numbers? I have an AOD gear indicator in my truck (came with a gauge cluster I installed, my transmission is a C6, non-overdrive) and it says P R N (D) D 1, with (D) being the encircled D you mentioned. I think some later trucks had (D), D and D1, but I'm not sure.
For what it's worth, I would just leave it in (D). (D) is automatic operation of all forward gears (1st, 2nd, 3rd, and 4th [overdrive]). If you're not going fast enough for the transmission to automatically shift into 4th, then it'll just stay in 3rd.
EDIT: K_nine summed up my big post in a single sentence. lol
Old Dec 8, 2010 | 02:58 PM
k_nine's Avatar
k_nine
sorry dude
Old Dec 8, 2010 | 03:09 PM
Old Hickory's Avatar
Old Hickory
As k_nine said, just leave it in the OD position and don't worry about it unless in a
situation where it shifts back and forth between OD and 3rd. Such a situation as this
might occur when going up a mountain road.
Old Dec 8, 2010 | 03:17 PM
MohaveMan's Avatar
MohaveMan
Stupid question ?
Wow guys, that was fast !! Thanks for the info. I have been driving in the apparent over drive so from what you say that is the right selection. I appreciate you taking the time to answer my question and in such a timely manner. If I can ever be of assistance to anyone I won't hesitate to answer the best that I can. I guess that is all any of us can do. lol Thanks again for the help. MM
Forgot to say that I have a 1984 F-150 with a C-6 tranny w/overdrive. I drive with it in (D) unless it isn't doing right then I shift down to the D selection.
Old Dec 8, 2010 | 05:06 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Just to add,
If you are towing or hauling something heavy, leave it in D, without the circle. This is advise from the owners manual.
Going down a long steep grade, shift it into one of the lower gears. D or 1.
Old Dec 8, 2010 | 05:09 PM
bashby's Avatar
bashby
C6 didnt have OD, you probably have an AOD judging by your shift indicator
Old Dec 9, 2010 | 12:25 AM
TheKirbyMan
Originally Posted by k_nine
sorry dude
Aw man, no need to be sorry, I thought it was funny. lol
