Hey all,
Anyone know how to remove and bypass the clutch fan after installing electric fans on an 05 F250 6.0. Flex-A-Lite told me I couldn't put an electric fan on because the clutch fan couldn't be removed.
Thanks,
D
Not sure why you'd want to replace a 10K CFM fan with smaller ones anyway.
FWIW--The fan has a lot to do with a LOT of functions on this engine and will probably take some serious tuning to try and remove it from the strategy.
Fair enough. Just read so much about all these extra horses you can pick up and save the vibration on the water pump as well as easier changes of the serpentine belt. You'd be f....d trying to replace one in the bush. Almost impossible changing one in the shop LOL.
Thanks
Don
