largest tire size
Old Dec 8, 2010 | 12:34 AM
ford557SCJ's Avatar
ford557SCJ
largest tire size
Hello all,
just getting ready to do some stuff to my 2010 and i need some help,
I have 18x9 moto metal wheels with a -12mm offset and I was wondering what is the largest tire, height and width, that I can fit under her. No lift or leveling kit.
I realize I coulda probly searched this but what the heck, I need to get my first post in somewhere!
Old Dec 8, 2010 | 07:50 AM
Mudd460's Avatar
Mudd460
What model of truck do you have?
Old Dec 8, 2010 | 01:30 PM
ford557SCJ's Avatar
ford557SCJ
its a supercrew 5.4 3.55's
Old Dec 8, 2010 | 02:21 PM
cmdrost's Avatar
cmdrost
33's prob. Depending on how wide the rim is
I've seen the 35's on factory rims on a truck with 2" leveling kit.
Old Dec 8, 2010 | 07:55 PM
Mudd460's Avatar
Mudd460
I was wondering if it was a 4x4.
Old Dec 8, 2010 | 11:50 PM
ford557SCJ's Avatar
ford557SCJ
yes its 4wd, if you guys could get me the exact metric tire size that would be great. I know some of you guys got this kind of info.
thanks!
Old Dec 9, 2010 | 08:39 AM
BrianFX4's Avatar
BrianFX4
Well I know a 285/65R18 would fit for sure with no leveling kit. Not sure if a 295/65/18 would fit or not. Your best bet would be to find a good tire place in your area and see if they will do some fit tests on different sizes for you.
Old Dec 9, 2010 | 03:28 PM
Hybris's Avatar
Hybris
295's are only a half inch larger than the 285's in fact you could fit 305/65/18's and stay at about 33 inches exactly.
Old Dec 9, 2010 | 03:50 PM
04XLTRUNNER's Avatar
04XLTRUNNER
35s will fit with the factory fx4 20's. not sure about aftermarket wheels.
Old Dec 9, 2010 | 04:45 PM
BrianFX4's Avatar
BrianFX4
The OP said he did not have a leveling or lift kit so I dont think 35s will fit no matter what wheels you use.
I had 305/65/18s on my 04 F150 with leveling kit and still had to trim some plastic out of the wheel well but you could definitely have them test fitted.
Old Dec 9, 2010 | 07:28 PM
ford557SCJ's Avatar
ford557SCJ
Thanks guys! I think il go with some 285/65's and call her good. One more question, I cant decide between good year wranglers or nitto trail grapplers, any expericences with those tires on here? I have 35" bfg mud t/a's on my 76 but they seem to howl quite loudly so im gona stay away from those i think.
Old Dec 9, 2010 | 10:17 PM
Hybris's Avatar
Hybris
Just got the Goodyear Warngler Silent Armor in E rated 285/75/R16 almost 1500 miles ago and I love them but two things that I have found so far:
1. 40 psi doesn't feel very good and wonders noticeably I had mine put up to 80 and they ride hard but true.
2. My tread depth is 16/32 and the rubber they use is soft even in fairly cold conditions hence the reason they are stamped with mountain/snowflake.
Because of the soft rubber even at 80 psi you may feel a little squirm when stopping but that might be my brakes.
Old Dec 9, 2010 | 11:27 PM
Matts72's Avatar
Matts72
I have the Goodyear SilentArmor Wranglers and they are undoubtedly the best A/T tire I've ever run. My job takes me 300+ miles a day, with 60+ on gravel roads and these tires do not complain. They aren't noisy at all either. I do switch to a studded snow tire for winter, but I got caught off guard this year and spent two weeks playing in the snow with the Wranglers and they did very well, but ice is a different story.
Old Dec 10, 2010 | 08:07 PM
ford557SCJ's Avatar
ford557SCJ
I meant to say goodyear wrangler duratracs, sorry
Old Dec 12, 2010 | 08:18 PM
brandon4's Avatar
brandon4
My 10 has 325 60 18 with same size wheels as you. 2in leveling. Km2s and i really like them.
MRN III
Feb 12, 2021 12:31 PM
Rudiak
Dec 9, 2017 08:52 AM
Bat4x4
Nov 23, 2017 08:37 PM
Chris89lx
Oct 10, 2006 09:21 PM
