need help asap
Old Dec 6, 2010 | 11:26 PM
cvincent's Avatar
cvincent
need help asap
i just got my ex with 7.3 back from shop today., had oil change, and some kind of oil tube changed that was leaking
i always like to check the oil after it is done, so went to pull the stick out and it seemed very hard to get out, now it will not go back in at all
i just happened to stop and get some rubber vacuum caps today and one fits over the stick tube, is it ok to run the truck like this?
i am sitting in a parking lot 35 miles from home and need to bring it 40 miles back into the shop in the morn
thinking it will be fine but with my luck that is supposed to breathe there and it will hurt my engine to be sealed up like that?????
any help would be great
thank you!
Old Dec 6, 2010 | 11:29 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Mine's a bear to get in and out sometimes - I just do my best to line it up but often have to use both hands to get it back in and seated. You might try that. Just grip as close as you can to the end as it's going back in the tube.
As for your cap being OK, I would think so. Worst case is you'll blow a little oil on your engine, but it shouldn't be much, if any.
Old Dec 7, 2010 | 12:23 AM
cvincent's Avatar
cvincent
well i am heading home, hope it is ok with the cap on it
i have 2 7.3 trucks and neither of them have ever been hard to get the dipstick out or in, i dont like that and want it fixed
i did try angling it several different ways but i could not get it to budge, it feels like something is stuck in there, i hope not
will take it back to the shop in the morn
thanks for the help
Old Dec 7, 2010 | 01:19 AM
big poppa's Avatar
big poppa
Wonder if they boogered up something at the opening into the oil pan hence the hard in and out dipstick removal.. Ussually its the o-ring from the pan to the tube that goes bad, never heard of the tube itself rusting completely out but I guess its possible..Mine just has at the top a very light surface rust but it wipes off of sorts.
Old Dec 7, 2010 | 01:30 AM
JockD's Avatar
JockD
Crawl under the truck and inspect the dipstick tube carefully. It doesn't take much of a tweak to make the dipstick hard to insert. My guess is that when they worked on the oil leak (Oil Cooler?) they jacked up the engine for access and in the process bent the dipstick tube.
Old Dec 7, 2010 | 02:13 AM
orng1's Avatar
orng1
My explorer is difficult but I just twist it and it seems to line up.
Old Dec 7, 2010 | 07:04 AM
Supercab's Avatar
Supercab
+1 and IF your shop "damaged" anything make darn sure they make it right!
Old Dec 7, 2010 | 07:52 AM
PaysonPSD's Avatar
PaysonPSD
I had the same problem. Push the top of the dipsick tube toward the firewall, just a little bit and try again. If it is still tough to get in push a little more. After I got it pushed back to it's original position the dipstick now glides in and out easily. I must have bent the brackey while working under the hood.
EDIT : You can also loosen up the 13mm nut that holds the dipstick tube bracket and reposition it while trying to push in the dipstick.
