Quick fuel bowl ?
Old Dec 6, 2010 | 07:19 PM
ad326's Avatar
ad326
Quick fuel bowl ?
I have a fuel leak and its coming from the hard fuel line on the backside of the fuel bowl, is this the primary fuel line or a return line? Also, how should this line be connected? Mine only has a black hard rubber sleeve that is fitted over the hard fuel line and slides over the connector for the bowl? I would think there should be some sort of fitting but I have had the truck almost a year now and it has just started to leak, thanks!!
Adam
Old Dec 6, 2010 | 07:24 PM
tritonman2001's Avatar
tritonman2001
That is the drain pipe. is it leaking from there or the drain its self. the most common leak is the o-rings where the drain bolts to the bowl. It is an easy fix, just remove the 4 #20 torques screws and replace the two o-rings. Get them from clay at riffraff or from guzzels diesel o-rings. Hope this helps.
Old Dec 6, 2010 | 07:29 PM
clintbonnie's Avatar
clintbonnie
See the following forum thread for more info...and instructions on how to change them out..
https://www.ford-trucks.com/forums/1...-3-diesal.html
Bigcat350's Avatar
Bigcat350
Adam
Check this site out. Should help you some.
Welcome to guzzle's PSD Fuel Filter Drain Valve Repair Web Page
Old Dec 6, 2010 | 07:33 PM
ad326's Avatar
ad326
Thanks Tritonman! Where does this drain line go to? Any harm in this thing leaking for a couple days until the o-rings come in?
Old Dec 6, 2010 | 07:38 PM
tritonman2001
The line runs down the front of the engine but if it is leaking from the o-rings then it will go in the valley. You could just flip the o-rings until the new ones get there. That is what I did because where I park at work I got tired of cleaning up fuel every day
Old Dec 6, 2010 | 07:49 PM
rbaker6336's Avatar
rbaker6336
You can go to a hardware store in the plumbing dept and pick up buna o-rings,mine have been in there about 4 years
Old Dec 6, 2010 | 07:52 PM
ad326's Avatar
ad326
Which ones you guys prefer? Black, brown or blue?
Old Dec 6, 2010 | 09:31 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
get the milspec blue ones..............
