no run
Old Dec 5, 2010 | 10:48 PM
square-body-lover's Avatar
square-body-lover
no run
i am at my wits end . i changed my stock intake to a 4bbl edlebrock dual plane. it has a 2bbl-4bbl adapter plate, I just rebuilt the carb my vacuum lines are brand new. but now heres the problem when it does fire it revs right up then dies right away, when i give it a bit of gas it sputters and dies. All i want is to get 'er running cause i'm doing an engine swap asap but need the truck sooner.
Old Dec 6, 2010 | 03:15 PM
smokeyb97's Avatar
smokeyb97
Re-check all vaccum sources. I forgot about the plug on the back of my carb after installing and it would start but run rough then die until I found my mistake. Not sayoing this is your problem, just a suggestion. Hope you find the problem.
Old Dec 13, 2010 | 07:00 PM
square-body-lover
Question
i have every vacuum line connected and still nothing is there a possibility that it is my carb?
