Help.. Acceleration problems. 5.4 2000
Currently proud owner of 2000 5.4 f250. Having some issues as of late. The truck doesn't accelerate properly, it bogs down and when at cruise, set at any speed, Its jerky, cuts in out, as if it were being starved of fuel. So far I have dropped the tank replaced the fuel pump, fuel filter, spark plugs, air filter, mass air flow sensor, and throttle body position sensor. It idles fine. Any help would be greatly appreciated. I am out of ideas and its getting close to Christmas.
Well after all the money, parts, and time I put into it; I finally broke down yesterday and took it to my local shop. I wish I would have went with my gut instinct and tried 1 more part. It was the #2 coil over. I had went bad. The replaced all of the coil over boots and the #2 coil over for 300$. It fixed the problem, The only thing is I could have replaced all 8 myself for under 250$. Thanks gain everybody for your input well appreciated.
madMatador78
1999 to 2016 Super Duty
06-03-2014 08:32 AM
2000, 2004, 2007, 54, accelaration, acceleration, acceloration, aceleration, boggs, bogs, c6500, f250, ford, gmc, problem, problems, throttle
