maybe a bad alternator?
It turns out cleaning the terminals has not made any difference however I think I have pinpointed exactly when the problem occurs. At high rpms right before when I usually upshift, I'll guess about 3 - 3.5k, the headlights and instrument panel go dim. Then as soon as I engage in the next gear and the rpms fall, the lights immediately return to normal. Or, if I wind up the engine but let it slow down, staying the the same gear, the lights return to normal right when the engine slows past a certain point. And this is predictable and happens every time.
Searching google shows that people are solving this by replacing the bushes in the alternator and replacing the voltage regulator. My question is, is it necessary to replace the volt regulator? Also, would it be better just to replace to whole alternator as opposed to trying to rebuild it?
Thanks.
Thanks.
If it were mine, I'd replace the alternator (and regulator if its separate); the way my lucks runs I'd spend a half a day replacing the brushes then a day later the bearings would fail.
Check the belt and belt tension too.
I would suspect the regulator more tho since it acts up only at high rpm.
I couldn't locate any brushes at any of the major parts stores in the area, but I found this Alternator Brush Assembly on Napa's website at this link: Store Locator | NAPA Online
Apparently for $12 and taking off two screws at the volt regulator you just drop this in as a direct replacement. However the only one listed is for the 4.0L engine and there is nothing for the 2.5L engine. Does anyone know if the alternators used with the 4.0 trucks are any different than those from the 2.5L trucks?
So far so good after a half hour drive however I'm hearing a faint high pitched "wheeeeew" sound when revving the engine when parked. I tried to be careful to center the belt on all the pulleys when putting it back on, the belt was my first thought about what it could be. But its not very noticeable and after a test drive the sound seems to be going away.
