Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Wont Idle
Old Dec 5, 2010 | 08:40 AM
ford351c's Avatar
ford351c
Wont Idle
Hello,
I have a 2001 Ford Escape 4x4 6cyl. The problem is it wont idle. It will start and immeadiatly stall. If I start it with my foot on the gas it will continue to run but as soon as I left my foot off the pedal the engine dies. THis didnt come on gradual, it was fine one day and like this the next. I have changed the fuel filter.
Any Ideas?
Thanks in Advance!!!
Old Dec 5, 2010 | 08:47 AM
scott91370's Avatar
scott91370
Could be a few things.
1) IAC solenoid
2) Battery
3) Intake gaskets
Old Dec 5, 2010 | 09:52 PM
DaveinRoswell's Avatar
DaveinRoswell
My bet would be the idle air control valve (IAC). I have had to replace mine twice on my 2001 escape in the 9 years I have owned it. It is right on top of the engine (silver cylinder).
Old Dec 6, 2010 | 08:43 AM
sundvl76's Avatar
sundvl76
I've just been through something like this with my '05 V-6 Mariner, although not as severe as yours.
It was suggested to me to remove the IAC and clean it with MAF sensor spray cleaner. That did help mine quite a bit and saved - for now - buying a new IAC valve.
Your results may vary, as you might have a completely failed valve instead of just a dirty one. It may be worth a try as a can of the cleaner is only $6 - $7 and the MAF needs periodic cleaning anyway.
Pricing for a new one seemed to be the best at O'Reilly Auto.
Old Dec 12, 2010 | 08:34 AM
ford351c's Avatar
ford351c
Looks like it was the idle Air control valve. Cleaned it with MAF spray. Worked fine now for over a week
Old Dec 12, 2010 | 12:48 PM
sundvl76's Avatar
sundvl76
Good to hear someone else was able to solve the problem with a good cleaning. I'd guess many of these are replaced unnecessarily.
Neal
Old Dec 13, 2010 | 11:50 AM
Brown Kid's Avatar
Brown Kid
We changed ours on Sunday, cranked this morning ,but still had a little rough idle.
Could be the weather , it was around 28 degrees this morning here in Houston.
Old Dec 13, 2010 | 11:53 AM
Brown Kid's Avatar
Brown Kid
did anyone use an fuel additive or fuel injector cleaner when they changed theirs ?
The Escape runs a lot better ,but this morning , it still had a little rough ide.
Old Dec 13, 2010 | 02:05 PM
sundvl76's Avatar
sundvl76
Another poster told me that the injectors are "self-cleaning". That may be true, I don't know. I've not used an additive, I just try to use Chevron whenever the price is right, for whatever that's worth.
I also cleaned the MAF, and at least in my '05 Mariner, the ambient air temp sensor is in the same unit, so it got cleaned at the same time. You might try that next.
Could be plugs, depending on mileage, but most report they are still in good shape at 125K+ miles. If you are well over that on originals, it may be time.
Neal
Old Dec 13, 2010 | 02:38 PM
Brown Kid's Avatar
Brown Kid
Neal
Thanks , we got a full tune up this past spring.
I will try the mass air sensor , the fuel filter was changed 2 weeks ago, it was dirty.
Old Dec 13, 2010 | 04:25 PM
scottss80's Avatar
scottss80
Brown Kid,
Is the rough idle only during start up and the initial warm up, or all the time? How many miles do you have on you Escape?
Scott
Old Dec 13, 2010 | 04:39 PM
Brown Kid's Avatar
Brown Kid
Originally Posted by scottss80
Brown Kid,
Scott
Just at start up for the first few minutes of driving , then it drives fine.
shark1979
Aug 1, 2010 02:54 PM
atmotion
Jan 2, 2010 02:27 PM
FFemt5287
Aug 23, 2007 06:20 PM
fireman725
Bronco II
Jan 6, 2007 09:32 AM
New To Ford
2004 - 2008 F150
16
Dec 27, 2005 06:18 PM
