Leaky rear pinion seal
I like the way you think, and there were some tools I had to have . It was a negotiated fathers day gift .
on
The pinion gear likes to run a little snug to insure proper clearances at the contact point of the teeth and also the nut will stay tight due to the resistance of the crush sleeve. I have fixed hundreds of diffs and the amount of drag isn't as critical as most people think. As a diff wears out the pinion bearings get loose and the nut can back off. When you tighten the nut back up it crushes the sleeve a bit more and restores the drag to the pinion bearings and also restores the needed resistance to the nut to keep it tight. Keep your inch pound wrench in the rollaway and just make sure it has a little drag. The worst wifes tale I've heard in here is that you can mark the position of the nut and return it to that mark. That only assures that you are back to the same place you were before but with more chance of the nut coming loose. You can also use a new nut and stake it with a punch but not necessary if you do what I said. I have seen diffs with lots of miles with pinions set way too tight and many with no drag at all and they were still working fine.
Sorry, not meaning to hijack the thread, but maybe my confusion could help others in a similar spot.
I guess that isn't correct after all.
Most mechanics will not do it this way because it is time consuming.
on
In a perfect world, yes, there is a torque setting but it needs to be measured with the axles pulled out so the diff can spin freely. You measure the rotational force required to maintain the pinion gear and ring gear spinning (with the axles pulled out) with a beam-style torque wrench. If my memory serves me it is 15-30 inch pounds for new bearings and half that for used bearings.
When you say this, do you mean with the axles in or axles out?
Received 5,160 Likes
on
Lex the ''drag'' should be checked without the axles (or anything else) but us seasoned diff guys know the ''feel'' we're after......
...... of course the drag is measured after you start spinning the pinion gear in the housing ....
on
Right, I have seen them so tight I could barely turn them and still working perfectly after many thousands of miles, and I have seen many with almost no drag because the drag disappears as the bearings wear. The only purpose of the drag is to assure you that the bearings are snug. Everybody that doesn't have experience with them gets too hung up on inch pounds. I have rebuilt hundreds of rear ends and never touched an inch pound wrench.
#30
Jeff
