Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
MKX / Edge owners
Old 10-26-2010, 12:36 PM
baracade's Avatar
baracade
baracade is offline
MKX / Edge owners
We bought a 2010 MKX last month and I was wondering how many of you change your oil and do you use synthetic or regular oil (aka dino oil)?
We had a 2003 Excursion 7.3L that we traded in and I changed the oil in it a home. Just wondering if the synthetic is worth the cost, since Ford recomends it. I know I can save money by changing it myself and is definitly easier than the diesel engine. What proof will be needed for the warranty as to oil changes at home instead of the dealer?
Old 10-27-2010, 08:42 AM
merlynr's Avatar
merlynr
merlynr is offline
I have 4 vehicles on the road and the Edge is only one that I don't do the oil changes on. Bought it used from local Ford dealer and letting them do oil changes and I believe they use the blended oil which is syn and dino AFAIK.
Old 11-13-2010, 07:00 AM
thmitch79's Avatar
thmitch79
thmitch79 is offline
I change the oil in all three Ford engines in the driveway, '02 F150 5.4L, '07 Edge 3.5L and an '03 Fleetwood Southwind that has a Triton V10 in it. I use Motorcraft Syn Blend 5W20 in all of them. The Edge is the easiest to change the oil in BTW.
Old 12-04-2010, 09:53 PM
38Chevy454's Avatar
38Chevy454
38Chevy454 is offline
Change the oil myself in all of my vehicles. The Edge gets the Motorcraft 5W-20 synthetic blend every 5K. Edge is easy to change the oil, just get the front end up enough to get underneath it. Wal-Mart has the Motorcraft oil for cheap, $14 for 5 qts around here, it was less until recently. Edge takes a little over 5.5 quarts for a complete change with new filter. I use either Motorcraft or Fleetgard filters. No Fram for me.
I like to change my own oil as it gives me a chance to see what's going on underneath and check things over. Plus I can make sure the oil pan is not stripped out or left too loose so it can fall out later.
Old 12-05-2010, 09:50 AM
thmitch79's Avatar
thmitch79
Exactly why I do my own as well.
bama fan
08-04-2016 05:25 AM
DerekShiekhi
07-24-2015 05:30 AM
rbsample
Crossovers
02-25-2011 09:13 PM
05v10
Crossovers
02-13-2011 08:39 AM
redford
Crossovers
51
10-27-2007 10:06 AM
Quick Reply: MKX / Edge owners
