SD has me stumped
Old Dec 4, 2010 | 09:24 PM
strokethis04's Avatar
strokethis04
SD has me stumped
Okay guys I own a 6.0 powerstroke, one morning i left my house and right there it just fell rlat on its face. I go to turn the truck back on and all the relays went crazy cruise control light was flickering. My friend came and scanned the truck said it was a bad ficm i replaced that now the truck does the same thing i think the gem module is bad i dont want to purchase anything else until i know for sure what the problem is. I need help guys.
Old Dec 4, 2010 | 11:04 PM
Franklin2's Avatar
Franklin2
Check your battery connections and the large battery cables.
Old Dec 5, 2010 | 07:07 AM
strokethis04
would that cause everything in the cab to do this? it has no problem cranking over.
Old Dec 5, 2010 | 10:20 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Sounds electrical to me! Have batteries load-tested.
Old Dec 5, 2010 | 12:44 PM
Franklin2's Avatar
Franklin2
Somewhere on this truck there will be smaller wires that are hooked to the same spot as some of the larger wires. This will be where they tap off for power to the rest of the truck. This is usually at the fender mounted or firewall mounted starter relay/solenoid. I would check the condition of the wires there also.
Old Dec 5, 2010 | 05:05 PM
strokethis04
Question
big time electrical issue I'm not sure what is going on the truck just cut off on me? Could a GEM module do this to me?
Old Dec 5, 2010 | 08:13 PM
Franklin2's Avatar
Franklin2
GEM module only controls the functions in the body like domelights, wipers, door locks, etc. if your truck even has a GEM. They quit using the GEM on the later trucks, so I don't even know if you have one or not.
Old Sep 1, 2011 | 08:28 PM
strokethis04
Turns out the issue was a shorted FICM harness.
