Sponsored by: Real Truck
f350 brake help
Old Dec 4, 2010 | 05:03 PM
mugsee18's Avatar
mugsee18
f350 brake help
i just did a brake job on 2002 f350 4x4 changed rear rotors calipers pads and front rotors and pads bleed the brakes and paddel is still soft when i turn on truck with truck off paddel pumps up fine and stays hard can some one give me i idea please thank you
Old Dec 4, 2010 | 05:49 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Moved to the Superduty forum.
WELCOME to FTE!
Old Dec 4, 2010 | 06:05 PM
carltonwebb's Avatar
carltonwebb
This may be a weird question but.....is it soft when sitting still and trying it or soft when driving down the road? I guess what am i asking is does it stop ok? Sometimes they feel off when sitting and putting the brake on but feel fine going down the road as u rarely put enough pressure on them in everyday usage as u do at dead stop following brake job.
Old Dec 5, 2010 | 08:34 AM
mugsee18's Avatar
mugsee18
Smile f350 soft brakes
both are soft when stopped and driving ,
Old Dec 5, 2010 | 12:43 PM
LxMan1's Avatar
LxMan1
It feels pumped up fine because with it not running, you lose the power assist.
Old Dec 5, 2010 | 01:49 PM
mugsee18's Avatar
mugsee18
Question 2002 f350 brakes
yes its turned on and i loose power assit rotors and rear capliers are changed pads are changed i don't know thank you
Old Dec 5, 2010 | 03:12 PM
carltonwebb
How does it stop? Why did u change the calipers? Was one stuck? When u bled the brakes, did u start with rt rear, leftrear, rt front and left front? If it stops fine and one of the calipers was stuck, it could account for why it feels different. Did u check the caliper slide pins that mount into the caliper bracket'?
