Below freezing in Ga this week for about 48hrs....starts fine.....I let it run for about 15 or 20 mins....a bit sluggish but after it warms up good to go....supposed to 15 Tuesday we will see then....
while it's nice to have that sucker plugged in, take a look at your electric meter rotation speed after you plug your truck in...might make you think twice if it isn't that cold outside.
For those living in a State where the roads are heavy salted as is the case here in northern IL, you may find that no matter how much one greases the block heater plug it will eventually rot as mine did after only three winter
Going down the road less traveled, I opted to cut off a two foot section of the rotten OEM wire and splice in a flexible commercial grade cord to act as a strain relief (since the OEM cord is not that flexible at below 10 F temps). Each wire splice was first soldered, a light covering of dielectric grease applied to each solder joint, then to each wire heat shrink was applied and a final layer of heat shrink appplied over the entire splice. On the other end of the cord extension I connected a Pass & Seymour watertight plug which also has a cap to protect plug blades when not plug in (really watertight). My extension cord also has the mating Pass & Seymour connector on it so the connection is truely watertight (manufacture claims to be watertight for 1000 psi high pressure hose-down).
Both mating connectors available from the local Lowes:
I am glad electricity is cheap here in SC!! I have it on about 3 hours before the truck starts when it drops below 25ish. It does sound a helluva lot better when it starts, but the truck is definitely still cold, no warm air for a while, and the temp gage is still pegged at the bottom. But it got rid of that 'clanking' sound on the first few minutes after starting.
I bought the Ford OEM cord. It is a nice cord, but for the price, I am sure the ebay cords are just as good and 1/4 the price. It is almost impossible to get the OEM cord to go where Ford intended without removing the engine. So you end up zip tying it wherever you can and not using many of the fancy push pins that Ford placed on the loom. You need to take off the right front wheel and splash guard to get in there and it is still a PITA to get it to where Ford wants it to be.
we have a 01 f550 and a 04 f350 both were bought in Georgia and both came with plug cords. and i have seen 2 other trucks that my buddies have(both 2004 also) and both have the plug cords. wondering why our georgia trucks have cords while alot of other people are getting theirs without plugs? was it a option that just happened to be on our trucks because i thought they were standard?
04 and earlier trucks came with them installed all ready. 05's and newer were an option to some states, and already installed to Northern States. Or so I understand.
I received the one I ordered off ebay and got installed the other day - we're visiting family in NC and this morning we had ~5 inches of snow on the ground, I plugged the truck in for about 2 hours, when I went back out side there was obvious melting on the hood... not like running off, but you could tell there was heat under there and the snow was starting to melt. When I cranked it up, the ScanGuage showed 92* and the outside temp was ~29*. So far, so good for it's functionality/operability.
Ebay cord is doing fine, my electricity bill for December was 40 bucks higher than usual According to my inline meter, the heater is pulling about 7.9 amps or so. Right on track for 1000 watts.
Mine's doing well also. Believe it not, lately we've had night temps in the teens & 20's (in S Tx?) so it's been nice to plug it up at night and have heat in the AM.
For the record, my electricity bill was 40 bucks higher in Dec, I probably plugged in 15 times or so.
Not to sound like I'm picking a fight...but if your home is electrically heated (electric HVAC or heat pump). Kind of hard to to blame the 6.0L for the increase in the bill. But I will agree that your going to spin the meter a little faster by plugging the block heater in. I don't have a link to it right off the top of my head...but last winter a couple of us agreed to disagree on which is cheaper...letting the truck warm up by idling or using the block heater. Both ways your going to speed some $$$ on either fuel or electricity. Personally, I'm a block heater kind of guy...
The block heater uses about 1000W so it does consume some electricity, but this was also a colder than normal Dec for most of us. My electric bill was $100 higher this Dec and I never plugged it in (didn't have it installed yet).
I have been pleasantly surprised how well the 5W-40 synthetic has helped with cold starts - nice and smooth even in the 20's. With 15W-40 it would crank slow and lack power until the EOT was at least 70.
