Need a little help here ?
Old Dec 3, 2010 | 02:55 PM
ah1988's Avatar
ah1988
All right, when i am turning the stering wheel in my truck while going down the road, its only on sort of sharp turns it makes like a crunch sound and it only dose it while its going down the road not when sitting in drive way turning wheel i looked and nothing is touching the tire , nothing is hanging lose it all looks sound and secure, but it obviously isnt by making that sound any ideas on what it could be ?
Old Dec 3, 2010 | 03:34 PM
wreckinball's Avatar
wreckinball
is it consistent through the turn or just a quick crunch?
Old Dec 3, 2010 | 03:40 PM
ah1988's Avatar
ah1988
it is a quick crunch,what ever is making that sound dose it soon as i make the turn, it only dose it when i am turning a bit sharp it dosent do it on every turn ,it is excspesially i dont know how to say it,but it is crunchyer when i am turning as i am hitting a hill or large bump.
it is not a harsh crunch like a soda can it sounds softer ,it is hard to describe but i want to fix it asap
Old Dec 3, 2010 | 05:25 PM
tecgod13's Avatar
tecgod13
Check your ball joints, tie rod ends, suspension bushings (leaf spring or radius arm) and front axle u-joints (if 4wd). Any of those might be causing the noise.
Old Dec 3, 2010 | 06:29 PM
ah1988's Avatar
ah1988
I think i know what is wrong now i dont know what the rod is called but the po was exremely cheap in repairing his truck and he wrapped a yellow tow rope around this bar that has a rubber stopper , ill just post a pic tomorow to much mumbo jumboto type !
Old Dec 4, 2010 | 09:36 AM
ah1988's Avatar
ah1988
Here is the pic, could someone tell me what this is call i think this is my crunching problem you can see where all the rubber has sort of blown out of it what do i neeed to fix this what is the part called ?
Old Dec 4, 2010 | 09:50 AM
rodneywar's Avatar
rodneywar
thats the swaybar mount bushing
Old Dec 4, 2010 | 09:54 AM
ah1988's Avatar
ah1988
could that be causing the crunch when i turn ?
Do i just get the bushing at napa ?
Old Dec 4, 2010 | 09:55 AM
rodneywar's Avatar
rodneywar
could be yea napa should sell em repace em see what happens they are shot i have never seen em that bad
Old Dec 4, 2010 | 09:58 AM
rodneywar's Avatar
rodneywar
you need to measure the diameter of the bar they came in 2 sizes 1 inch and 1 1/8ths
Old Dec 4, 2010 | 09:59 AM
ah1988's Avatar
ah1988
i thik the po was pulling it out of the mud and he attached the tow rope to the sway bar and the rope slid into the bushing the bushing housing is all bent out of whack he actuallu left the knot of the tow rope pinned under the bushing ahd just cut the rest of the rope off i think , the truck must have been in like axle deep mud the whole underside of the truck is caked in it i figured it would help keep rust from forming
Old Dec 4, 2010 | 10:03 AM
ah1988's Avatar
ah1988
Thanks for your help ,
Old Dec 4, 2010 | 10:08 AM
rodneywar's Avatar
rodneywar
Sway Bar Bushing - Front Susp
Product Line: Master Ride Chassis
Part Number: MRC HB1629
Price: 13.99 Each
this id for 1 1/8 bar
Old Dec 4, 2010 | 10:09 AM
rodneywar's Avatar
rodneywar
rust will form under the mud i have seen it happen
Old Dec 4, 2010 | 10:17 AM
ah1988's Avatar
ah1988
I guess i should better get scraping and see if there is any rust i hate rust!
