Excursion / expedition overhead console
Old 12-03-2010, 02:20 PM
al1270's Avatar
al1270
al1270 is offline
First of all I love the site and my new/used 00 EX. My daughter somehow (it may of be broke already) pulled and broke the main overhead/map light in the overhead console. I have been looking around and the expedition 97 to about 03 looks the same. I can get one from ebay pretty cheap compared to the one for the EX. Anyone do this or know part numbers or where I can get part numbers to compare?
Old 12-04-2010, 06:15 AM
al1270's Avatar
al1270
al1270 is offline
No info or ideas? No one owns an EX and an Expedition?
Old 12-04-2010, 10:16 AM
RMBC Freeride's Avatar
RMBC Freeride
RMBC Freeride is offline
I believe they are the same. I think I saw one at the salvage yard on an Expy, and thought to myself "that looks just like the one in my X". Other than that I have no first-hand info to back up that claim. Sorry.
Old 12-04-2010, 10:39 AM
drumminguy81's Avatar
drumminguy81
drumminguy81 is offline
it is the same that is what i used to fix mine.. the only difference is the mpg computer and the rear vent switches other than that the console is the same. i picked up an entire console off ebay for around 30 shipped swapped out the parts that were broken on mine and resold the console with the broken parts for more than i paid origionally.. never know what someone might need..
Old 12-04-2010, 10:43 AM
jh818's Avatar
jh818
jh818 is offline
They are made from the same mold for sure. I had purchased one off of ebay that came off of an Expedition so I could fix one of the sunglasses doors. The color may be slightly different. I know the lens color on the computer off the Expedition is blue where the Excursion is green. I can't say if the trip computer is calibrated the same. I didn't change it. I only changed the outer plastic trim.
Old 12-04-2010, 10:48 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
ohhh neat, id rather have blue, maybe i should find me a lense cover
Old 12-04-2010, 10:57 AM
jh818's Avatar
jh818
jh818 is offline
Yeah, it did look cool. Then I realized that it didn't match my digital odometer color and switched it back to green. I sold it on CL to a guy wanting to replace the dome lights.
Old 12-04-2010, 11:12 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
what are all the things the ditital odo does over the mechanical/digital? does it have different features, or just the total miles driven?
Old 12-04-2010, 12:05 PM
RMBC Freeride
Reps sent to drumminguy81 and jh818 for having much better answers than I did on this one. Thanks guys!
Old 12-04-2010, 02:03 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
nothing, the digital one actuly kinda sucks because you can only see the odo or miles driven(trip) but not both at the same time like the mechanical one. also if your battery goes dead you loose your tripomiter(sp) reading and it goes back to 0.
the 99-up expeditons will have a green display the 97-98s had the blueish.
Old 12-04-2010, 02:09 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
i bet it would be easy to swap the clusters since the mechanical one is ran off a stepper motor so its actually a digital signal probably would have to change the plugs tho since the plugs going into the cluster might be different, i would have to see the mitchel pinouts
Old 12-04-2010, 02:14 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
yeah i think it would be a big pain in the butt for not much gain..actuly none. other thing is the 02-05's have a trans temp gauge in them.
Old 12-04-2010, 02:38 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
what gauge are they giving up to make space for a volt gauge? i have a aftermarket tras temp but wouldnt mind another.
Old 12-04-2010, 02:43 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
without looking, i think you loose the voltage gauge and gain the trans temp gauge on the 02-05s.
Old 12-04-2010, 02:51 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
wonder if the one like i have with the electrical mechanical odometer you can pry the millage numbers to ones you want if you take that cover off the gauges.
Quick Reply: Excursion / expedition overhead console
