Difference between F350 and F250 SRW
Old 12-03-2010, 10:19 AM
SuperDoodieDutyDude's Avatar
SuperDoodieDutyDude
SuperDoodieDutyDude is offline
I didn't notice until after I bought the 250, but the 350 sits higher in the rear than a 250 I assume because of stiffer springs. I prefer the way the 350 sits. Anyone know how much higher the rear of the SRW 350 sits than the 250? I would be interested in raising the rear of the 250 to look like the 350. Is the only difference between the SRW 350 and the 250 the stiffer rear springs?
Old 12-03-2010, 10:39 AM
tross's Avatar
tross
tross is offline
I was under the impression that the only difference was an overload leaf on the 350 spring that didn't come into play until significant load was applied. Maybe it sits a litle higher because of the thickness of the extra leaf?
Old 12-03-2010, 10:55 AM
EpicCowlick's Avatar
EpicCowlick
EpicCowlick is offline
This is the F350 spring pack. You can see four springs:
  • The highest or most bent one is to control axle wrap
  • 2 and 3 are normal load bearing
  • 4th or lowest is the overload.
And of course, they are all sitting on top of the block.
I don't have a picture of a F250.
Old 12-03-2010, 11:12 AM
Dave XLT's Avatar
Dave XLT
Dave XLT is offline
Dave XLT
the spring blocks are two inches higher on the 350 than the 250 I know bwcause I put the 250 ones on my 350 to lower the back for my 5th wheel. I baught the blocks from the dealer.
Old 12-03-2010, 11:13 AM
PowerStrokeHD's Avatar
PowerStrokeHD
PowerStrokeHD is offline
The axle blocks is the main difference when it comes to height. The F-350 uses a block that is a couple of inches taller then what is used on the F-250. It would be a fairly simple swap out that should not cost all that much...
Old 12-03-2010, 12:05 PM
Blubeast01's Avatar
Blubeast01
Blubeast01 is offline
The F250 has a 2" lift block, the 350 has a 4" lift block. I put the 4" lift block on my old F250 so that my truck would sit level when my 5 th wheel was on it. I ordered the lift blocks on line from a site that sells Ford OEM parts and then had an offroad shop install them.
Old 12-04-2010, 08:09 AM
SuperDoodieDutyDude
anyone have part numbers for the F350 blocks?
Old 12-04-2010, 08:18 AM
Tom's Avatar
Tom
Tom is offline
Wow, did you run out and snap a pic for this thread? That's some dedication!
For what it's worth, the "most bent one" is an overload spring and has nothing to do with axle wrap. It's a third stage to the spring, whereas the F250s don't have it unless they have the camper package.
Old 12-04-2010, 09:46 AM
rickatic's Avatar
rickatic
rickatic is offline
Tom
Good stuff
Thanks
Old 12-04-2010, 08:33 PM
AlexWV's Avatar
AlexWV
AlexWV is offline
Not to be a know it all or anything but just to keep the facts straight, the highest, most bent one, is the the overload spring...
Old 12-04-2010, 10:06 PM
Big-Sarge's Avatar
Big-Sarge
Big-Sarge is offline
Epic......that is the dirtest leaf springs I have ever seen..... You need to bust out that power-washer of yours!!
Old 06-21-2011, 07:21 PM
lexustbs's Avatar
lexustbs
lexustbs is offline
did you end up doing this mod? The part I cant figure out is when you unbolt the axle, how do you keep everything lined up? Does the axle have some type of flange that sits only in one spot? I guess I'm worried about the alignment of the driveshaft and all that after I install the spacer. Somebody give me some tips on how to install.
Old 06-21-2011, 08:10 PM
EpicCowlick
Did you get the AutoSpring spacers Lex? If so, it's no big deal.
Old 06-21-2011, 08:40 PM
lexustbs's Avatar
lexustbs
lexustbs is offline
No. I was just going to get the 350 OEM 4" spacer and new u bolts. What's the best way to do this? Jack up the truc by the frame just till the wheels come off the ground, then undo the u bolts and change the blocks?
Old 06-21-2011, 10:18 PM
biz4two's Avatar
biz4two
biz4two is offline
Thumbs up
What has worked for me in the past...
DOING one side at a time:
Is that I jack the truck up with a floor jack by the axle until I get about 6 or 8 inches under the tire. Then I support the frame with appropriate jack stands. I begin un-bolting the u-bolts and remove the nuts. Remove the u-bolts. Now begin lowing the floor jack slowly...until the F250 block can be removed. Lower another 2 inches so the F350 block will fit. Begin jacking up the axle until the F350 block is installed with some pressure. Now install the new longer F350 u-bolts with NEW nuts. Torque to specs.
Now...off to the other side...and repeat.
Really takes less than an hour...and really easy to do. Good luck!
biz
Quick Reply: Difference between F350 and F250 SRW
