Last chance chat 2010
Good morning ND.
How you doing Corey? Did you guys get nailed over there in Montana?
I sure wished we got 15" like Williston did. We always get missed around here.
Dave, did you get much snow down there in SA? Are you still hauling that car over to Pauls? I'm hoping my alt will hold out to make it down to the desert today. Its been acting up on these really cold days. But it seems very intermittent so I think I'll be ok.
lol Should be a mess down there with the drifts and added snow.
Ya, I'm headed in now. Don't know if I'll make it to the desert tho. I have to move snow at the house yet, annd clean out the one stall in the shop. Plus my pickup seems to be pinging under load not a good thing. Sad part is everything checks out. So IDK about this thing.
Prob end up swappin this EFI for a Carb and running this setup on the International pickup I'm putting a 5.8 in.
Maybe I'll go play on some section lines by the house with my Dads Bronco or something.
Oh man that sucks! I sure hope you can work out that knock. Have you tried running a higher octane mix? Maybe mix a little leaded 110 octane in with your unleaded 91. Or just back the timing down a bit. Maybe its something as simple as your wires arcing. Sucks when its trial and error diagnosis.
Well if you do end up hitting up some section lines around there, let me know, your area is probably closer to me than the desert anyway. I'd come out and check it out.
So Dave, did you get it all cleanup around the house?
Well I ended up heading down to the desert, it was pretty sweet down there. I'd say average of 14" and plenty of 20"+ areas. Lots of hidden drop offs and logs though so it makes for a good time. I wanted to stay longer but it was getting dark so I think I'm going to try to head down again tomorrow for a hour or so.
