throttle position sensor maybe?
Old Dec 1, 2010 | 04:58 PM
fordmudgrappler's Avatar
fordmudgrappler
So I've noticed that when I drive my truck hard or drive it for awhile that when I stop and put it in park its idle is higher then normal. Normal idle for my truck in park is about 800 rpms or so but lately its been at about 1000 rpms. When I rev it up it will drop back to normal. Also if I rev it up hard it will slowly drop and normally will do its high idle thing. So I'm wondering if maybe the TPS is sticking? Or going bad? Any ideas fellas?
Old Dec 1, 2010 | 05:02 PM
DBGrif91's Avatar
DBGrif91
Sounds like an IAC problem.
Try pulling codes to see if anything comes up. Ford Fuel Injection » How To Run a Self-Test
Old Dec 1, 2010 | 05:04 PM
Conanski's Avatar
Conanski
Could be.. put pull the codes and know what the problem is instead of guessing at it.
Old Dec 1, 2010 | 05:07 PM
fordmudgrappler
Thanks guys ill pull em and see.
Old Dec 1, 2010 | 06:54 PM
L. Ward's Avatar
L. Ward
My vote goes for the Idle Air Control also, the 5.8 on my 90 5.8 Bronco would do the same thing. Pulled it and cleaned it and it was fine from there on.
Old Dec 1, 2010 | 08:40 PM
bc18's Avatar
bc18
backprobe the throttle position sensor and put an ohm meter to it. i believe if its over 1 ohm its bad but thats one way you can test your throttle position sensor you just need to look up exact specs of this sensor
