460 help
Old Dec 1, 2010 | 04:50 PM
cole45's Avatar
cole45
460 help
i have been searching for an inspection plate for a 460 hyrdo clutch. i ahve everything else set up for change but can't find this part. it has to to be the one for teh hydro with the "lip" on the bottom to hook to the bell housing. if anyone has one please email me with a price and pics if you can thanks.
Old Dec 1, 2010 | 05:07 PM
Franklin2's Avatar
Franklin2
If you can't find one, don't worry about it. I have run many vehicles without the inspection cover with no problems.
Old Dec 1, 2010 | 05:57 PM
cole45's Avatar
cole45
do you just leave the bottom open then?
Old Dec 1, 2010 | 06:09 PM
Franklin2's Avatar
Franklin2
Yep. I have done several swaps where I didn't have the proper cover, and though I at first didn't like the thought of leaving it open, I drove it like that anyway and never had any problems. I have done it so many times now, I would not let it hold the whole project up. If you find one later on, great. But you can certainly drive it till you find one, if you ever do.
Old Dec 1, 2010 | 08:27 PM
82F100SWB's Avatar
82F100SWB
On a 460, this isn't just an inspection plate like on a diesel. It's the spacer/starter locator like on a smallblock. Without it, the starter won't sit in the right position, and will most likely break the bellhousing.
Old Dec 1, 2010 | 08:36 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The plate goes on before the flywheel.
You can see the starter spacer in this photo.
<a href="http://www.flickr.com/photos/24183730@N03/2341398064/" title="IMG_1903 by Jim_Urrata, on Flickr"><img src="http://farm3.static.flickr.com/2230/2341398064_eee3888e15.jpg" width="375" height="500" alt="IMG_1903" /></a>
I have a bellhousing if yours is toast.
Old Dec 1, 2010 | 11:33 PM
Franklin2's Avatar
Franklin2
Another one of Ford's great ideas. I am assuming you are swapping from a auto to a manual? Or maybe a 4 speed to a 5 speed? If you get desperate, possibly you could use the old plate as a spacer like the other guys where talking about IF it uses the same starter. You might have to wack it off on the bottom though.
Old Dec 2, 2010 | 06:32 AM
cole45's Avatar
cole45
i have the plate from the 400 that is in it. i don't need the bell housing just the plate shown in the pic. ardwrkntrk do you have another one on hand by chance
Old Dec 2, 2010 | 07:13 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
No, sorry.
I kept that same plate when I swapped to the ZF-5
I only have the T-19's hydraulic bell housing.
Old Dec 2, 2010 | 10:36 AM
cole45's Avatar
cole45
do the five speeds run the same plate as well. if so might be easier to find.
Old Dec 2, 2010 | 11:30 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I am using the same plate with my ZF-5.
Didn't remove the flywheel from the donor, it was heat checked.
Old Dec 2, 2010 | 02:34 PM
cole45's Avatar
cole45
on a side note can you load a pics of the bell housing i think i might be missing a piece from the one i got. not sure how the external slave hooks in. used ot messing with small blocks
Old Dec 2, 2010 | 02:49 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sorry, I had to snap them and upload to Flickr.
The slave slides into this bracket.
Then a 5/16 head selftapping screw locks it in.
You can see the little hole in the lower inboard corner of the boss.
<a href="http://www.flickr.com/photos/24183730@N03/5226773135/" title="IMG_0424 by Jim_Urrata, on Flickr"><img src="http://farm6.static.flickr.com/5246/5226773135_57b80451a2.jpg" width="375" height="500" alt="IMG_0424" /></a>
<a href="http://www.flickr.com/photos/24183730@N03/5226772973/" title="IMG_0425 by Jim_Urrata, on Flickr"><img src="http://farm6.static.flickr.com/5087/5226772973_c762e14436.jpg" width="500" height="375" alt="IMG_0425" /></a>
Old Dec 2, 2010 | 02:55 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Here's one installed highlighting the head of the screw.
<a href="http://www.flickr.com/photos/24183730@N03/4929766670/" title="IMG_0259 by Jim_Urrata, on Flickr"><img src="http://farm5.static.flickr.com/4075/4929766670_ecde6dac9b.jpg" width="375" height="500" alt="IMG_0259" /></a>
I'm a computer imbecile, so I just used chalk rather than trying to add it digitally w/ photoshop.
Old Dec 2, 2010 | 05:20 PM
cole45's Avatar
cole45
thanks for the pics i thought i was missing the keeper part one more thing to find for make. back to the spacer first i guess.
