smog pump removal
Old Jan 15, 2003 | 06:53 PM
goofin's Avatar
goofin
smog pump removal
does anyone make a idler pulley bracket for removing smogpump on 87 5.o
Old Jan 15, 2003 | 08:36 PM
EPNCSU2006's Avatar
EPNCSU2006
smog pump removal
Check with Ford Motorsports, I think I saw one in their catalog.
Old Jan 16, 2003 | 08:07 AM
honney's Avatar
honney
smog pump removal
'87 5.0 should be serpentine, no? If so, you shouldn't need one, just let the belt go straight from your crank to your alt. You'll need a belt that's 2" shorter.
Old Jan 16, 2003 | 10:41 AM
goofin's Avatar
goofin
smog pump removal
invested a little time and found a few things out. PA emissions test will require a visual check at this time, ford motorsport makes a setup for removing the punp. that wont pass. by dropping the belt from the alt to the crank, smog pump pulley rides against belt. running the belt from alt to waterpump to crank to ps to air to tensioner to alt lets me retain the pump for visual check,just replace stock belt with short one after inspection. new belt fall in 79" range. when i stated int was a 87 5.0 i should have explained a little better, 87 f150 347 stoker holley carb. its a blast and im woking on a 428 windsor stroker for it
Old Jan 16, 2003 | 11:06 AM
honney's Avatar
honney
smog pump removal
You can also gut the pump, or just remove the pulley. If you remove the pulley (three simple bolts) the belt will clear the pump and then go from crank to alt. I ran like that for awhile.
Old Jan 17, 2003 | 12:23 PM
goofin's Avatar
goofin
smog pump removal
new belt size is 21mm x1995mm
Old Jan 17, 2003 | 12:37 PM
sixx pak's Avatar
sixx pak
smog pump removal
