1200 Mile Haul Tomorrow, Brakes are shot (Pics added 12/2)
Hi everyone, I hope your holiday was well.
I have a 2005 Powerstroke F250 with 156k on the clock.
A couple days ago, the brakes started grinding. I took a look in the back, and sure enough, the rear driver caliper was grinding on the rotors. No warning squeak or anything, just straight to grinding. Rear passenger is not grinding or squeaking. Still has some life left.
I bought a new set of rear rotors and a complete set of brake pads for all 4 corners a few days ago in order to replace the brakes. Well, today as I'm approaching a red light, I hit the brakes. The pedal hits the floor...nothing....I was able to stop, but definitely raised my bp a bit... I got out and took a look, brake fluid everywhere on the rear driver area and the pad had completely separated from the caliper.
I haven't taken everything apart first, but I wanted to check with you guys to find out if I'm in over my head. I have a 1200 mile road trip that I'm supposed to make tomorrow hauling a couple RTU's back from chicago. You can be sure I ain't starting this trip with no brakes! I can upload some pictures if that would help. Basically, the rear driver wheel, wheel well, and surrounding parts are completely soaked with brake fluid as well as a nice puddle where it's parked. The pad is in a completely different part of the rotor separated from the caliper. Upon visual inspection I can see the silver parts of the "slide pins" that the caliper moves along.
Any advice would be greatly appreciated. I've done brakes before so I'm fairly knowledgeable, but if this will require more technical work I'd like to know so I can make an appointment with a mechanic asap.
Thanks for the help,
William Pictures as requested. I'm in the process of removing the caliper so I'll update with more pics.
Sorry if my wording was confusing, I haven't put the new pads on yet. I intended to once they arrived in the mail, but now I see I have a bigger problem on my hands. It is possible that it was sticking before with the old pads since one is completely toast while the other has a little life left. Thanks for the info, William
...you could have worn the pad out to the point of the piston coming out of its bore. I find that a little hard to believe if it JUST started grinding. I have gone metal to metal before on brake pads (pad backing to rotor) and been fine...but is possiable.
Go get rear rotors, pads and calipers...do it all and be done with it. It sounds like your use your truck alot, so you should be extra aware of things wearing out...
Ive had the front pad slip out of the caliper before. Luckily it happend while parking at work and I felt the brakes go. I had new pads and rotors at home so I put a few weld beads on the brake pad so that it wouldnt fall out again so I could get home. I imagine that since there is fluid everywhere you will need to get a rebuilt caliper, rotor, dot3 fluid, pads, bleed the brakes and you will be good. Caliper is shot for sure since the piston had to rub the rotor. You can easily have your truck ready in an afternoon. I would go get the parts before the parts store close and fix it tonight. Get a Haynes manual if needed.
If I were you I'd go to the auto parts store. Get new rear calipers, brake cleaner, brake fluid..you have the pads...look strongly at the rotors and see if they need turned but you could get without it as long as you replace the rest.
You will need to address the rotors upon return unless they are ok now.
Hi everyone, thanks for the help. I have updated the original thread with pictures. I know they're kind of blurry, but I hope they help. Everything is exactly as it was when I removed the wheel. I have not moved everything. I am in the process of removing the caliper, just waiting for the wd-40 to do its job
Based upon the pics, I would be inclined to replace that one caliper with the moisture on it.
Looking at those rotors I think they are probably too worn down to save them. Although as I said orginally if you have to use them so you can get back on the road you could do that.
Keep in mind though that those new pads will not like that.
Does anyone know if the bolts holding the caliper on are reverse threaded? I can't seem to get them off. I've tried air tools and everything.
William
