ZF swap help
Old Dec 1, 2010 | 10:37 AM
k_nine's Avatar
k_nine
ZF swap help
i have a 1986 f250 extended cab with the 6.9 diesel,use to have a stick in it but didnt get a tranny with the truck.
looking for someone who's done a zf swap?
from what i found on the internet there are three different ones. doesnt it matter which one i get?
what will i need to get from the donor truck?
if someone has found a write up that would help me please sent me what you find greatly appreciated . just want to know what im getting in to before i start, and what parts im going to need. would like to have everything before i start.
thank the help
Old Dec 1, 2010 | 12:00 PM
fordnut forever's Avatar
fordnut forever
here's a start https://www.ford-trucks.com/forums/7...-pictures.html
Old Dec 1, 2010 | 12:15 PM
k_nine's Avatar
k_nine
great thanks
Old Dec 1, 2010 | 12:21 PM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...a-5-speed.html Have a read here also. Any ZF you get must have come from another diesel and must either be a 4x4 one or 4x2 depending on what you have.
Old Dec 1, 2010 | 12:29 PM
k_nine's Avatar
k_nine
thanks
im running a 1986 f250 diesel (6.9) 4x4
Old Dec 3, 2010 | 01:39 PM
k_nine's Avatar
k_nine
for anyone who's done thisswap what fly wheel did you use?
Old Dec 3, 2010 | 01:49 PM
Lazy K's Avatar
Lazy K
In that link farmert used the flywheel from a SMF kit for a 7.3.
Old Dec 3, 2010 | 01:54 PM
k_nine's Avatar
k_nine
ok and here is a dumb question, what is a smf?
Old Dec 3, 2010 | 02:31 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Single mass flywheel
Welcome to the forum K_nine
Old Dec 3, 2010 | 02:34 PM
k_nine's Avatar
k_nine
ok thanks.
Old Dec 3, 2010 | 05:04 PM
Franklin2's Avatar
Franklin2
I didn't know there were 3 different zf's. I only have heard of two, and the difference is the gear ratios.
Old Dec 3, 2010 | 05:13 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Dave,
There are two torque ratings 420 & 470 foot lbs. (ZF-5 42 & 47)
There are three bellhousings. Small block, 385 block and Diesel.
The diesels get a close ratio (taller first gear) than the big block.
Because they are rev limited and have more torque they aren't seen to need a 5.72 first, and only get 4.14.
Edit: Plus, of course the difference in tailhousings between 2wd and 4x4
Old Dec 3, 2010 | 07:51 PM
Diesel_Brad's Avatar
Diesel_Brad
To the OP. you either need a 4x4 trans from a diesel OR a trans from a 1988-97 diesel F-superduty(also reffered to as a F450 but it is not really)
There are actually more than tq differences between the zf5 s42and the zf5 s47
The s42 gear ratios(for a diesel)1987-95
1st Gear:
4.14
2nd Gear:
2.37
3rd Gear:
1.42
4th Gear:
1.00
5th Gear:
0.77
Rev Gear:
3.79
The s47 gear ratio(for a diesel)1995-99
1st Gear:
5.08
2nd Gear:
2.60
3rd Gear:
1.53
4th Gear:
1.00
5th Gear:
0.77
Rev Gear:
4.66
Old Dec 3, 2010 | 10:06 PM
Franklin2's Avatar
Franklin2
Looks like they wised up on that later zf. I love my zf, but I do not like it's reverse gear. It's too fast. Ok for unloaded normal backing up, but anything else means slipping the clutch or putting it in low range. I honestly don't know what a person does with this early transmission in a 2wd truck. Can you imagine trying to back up with a loaded trailer and not having low range from the transfer case?
Old Dec 4, 2010 | 05:10 AM
Diesel_Brad
My exact thoughts, that is why i am going nuts looking for a s47 for my powerstroke swap. that will be the trucks main use, trailer towing
