Help no start when cold
Old Dec 1, 2010 | 07:20 AM
arkredneck's Avatar
arkredneck
Ok so my truck won't start when cold and I know there are tons of threads on this but he is the ? It started for a min and died and when I crank it I'm getting a %54 ipr duty cycle and a 100 psi on the icp. I'm using a aeroforce scan gauge. I think these trucks need like 550 psi on the icp to start so kinda wondering why it's low and won't start the truck has fresh oil and its full
Old Dec 1, 2010 | 07:38 AM
arkredneck's Avatar
arkredneck
Ok so an update after cranking and cranking the icp finally stated to build pressure and then the oil gauge in the truck moved to the R in normal then it finally hit 550 or so on the icp and fired off and died did that a few more times then finally decided to run
Old Dec 1, 2010 | 07:07 PM
arkredneck's Avatar
arkredneck
I checked the hpop resovior after it sat for a few hours and it was full any ideas on why it wouldn't show low icp readings when trying to start when cold? The icp sensor us fairly new
Old Dec 1, 2010 | 08:00 PM
F350-6's Avatar
F350-6
How does it start when the engine is hot? Is there any white smoke after a cold start? Might be a sticking IPR.
