Which Windshield Wipers?
Old 11-30-2010, 10:21 AM
Dan Reinbold's Avatar
Dan Reinbold
Dan Reinbold is offline
I am in need of a good set of windshield wipers for my Ex. I live in Michigan and would like to get some honest opinions on what wipers are the best in the snow and rain we are in for. Front and Rear.
Old 11-30-2010, 10:43 AM
fgials's Avatar
fgials
fgials is offline
I'm down here in Mississippi and don't know much about the snow but we sure do get plenty of rain. I bought the Rain-x latitude and they are by far the best ones i have owned.
Old 11-30-2010, 10:54 AM
Dan Reinbold
Thanks, I saw them at Menard's for $12.99 each with a bottle of glass care product and get a $15 rebate. How much did you pay for yours?
http://menards.inserts2online.com/cu...p?drpStoreID=1
Old 11-30-2010, 11:03 AM
fgials's Avatar
fgials
fgials is offline
Mine were on sale but not for that cheap!
Old 11-30-2010, 11:09 AM
excursionism's Avatar
excursionism
excursionism is offline
+1 for the Rain-X Latitude wipers on the X...however they won't go back on the Sienna minivan. I have no idea why they streak more so than on the X. Looking at the Michelin Stealth Hybrid Wiper Blades as the next set on the Sienna.
Old 11-30-2010, 11:10 AM
TYZ78F150's Avatar
TYZ78F150
TYZ78F150 is offline
Also,
You can go bigger than 20" and get more coverage. Some say you can go as big as 24's on the front. I went with 22's and they are great. I think they're rain x brand.
Old 11-30-2010, 11:38 AM
CMPX2's Avatar
CMPX2
CMPX2 is offline
I replaced ours a few months ago and went with the Rain-X Latitudes as well. They were around $20 a piece and are well worth it.
Old 11-30-2010, 02:28 PM
mohrds's Avatar
mohrds
mohrds is offline
I'm running the Michelin Beam blades on my Ex.
I run a 26" on the Driver's side and a 24" on the passenger side. I'd say that is the biggest size that will fit without hitting anything.
They work perfectly in rain and snow.
Old 11-30-2010, 02:34 PM
wallz's Avatar
wallz
wallz is offline
I have tried several different types and am now on the rain X brand. Not too bad for the price, and the wipe of rainx to apply on the glass is the real bonus. I think that is more of the ticket to a good wiper is the application of a water beading compound on the glass. I get to see anything from sleet, heavy rain with wind or full out snow and find that the frameless work the best, again with a glass prep. That is the key, and apply everytime that you see the water not beading as well as after first application.
Old 11-30-2010, 02:47 PM
MPTonyT's Avatar
MPTonyT
MPTonyT is offline
I use the Bosch Icon's on my F250... I am truly impressed with the blades. I do get them at a good price since my wife works for Tires Plus Corporate but they are a hell of a blade. FL is pretty rough on the blades due to the sun and all and i only change these twice a year.
Bosch Clear the Way
Old 11-30-2010, 02:49 PM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
Rain-X up sized 2" front and back.....
and rain-x liquid in the washer fluid...
@ speed on the highway and you can sometimes run without wipers in the rain
(course it causes wrecks around you when you pass people with their wipers on full speed and see u without them on lol )
Old 11-30-2010, 03:21 PM
mohrds's Avatar
mohrds
mohrds is offline
I used to use the Icons but they don't seem to hold up well in winter. The end caps pop off and then the blade cover slides down. Probably not an issue in FL
You could probably go down to once a year if you would take a cotton ball with some rubbing alcohol every month or every 2 weeks in the hot summer and wipe the face of the blade where it contacts the glass. It removes the powdered rubber and exposes the healthy rubber and prevents cracks from forming. If the cotton snags, it has a crack and it is time to replace the blade.
Old 11-30-2010, 04:03 PM
MPTonyT's Avatar
MPTonyT
MPTonyT is offline
Thanks for the info. Yeah definitely don't see snow or temps that would allow snow to stick. I think I had an Icy Windshield once last year.
Old 11-30-2010, 04:09 PM
tdappleman's Avatar
tdappleman
tdappleman is offline
I've used several beam blades - the Michelin's mentioned above seemed to last the longest and handle heavy rain and freezing temperatures the best. I currently have the Bosch Icons on my Ex and will be going back to the Michelin blades when these wear out. Almost any beam blade will be better than the older metal spring loaded blades. The constant pressure across the beam will give you better performance than 4-6 pressure points on the normal blade.
Old 11-30-2010, 05:08 PM
jeronlines's Avatar
jeronlines
jeronlines is offline
Love my Rain X Latitude 24" in the front and 17" in the back. No streaks and a nice clean sweep. I'm looking forward to seeing how they perform in the snow and sleet this winter.
Quick Reply: Which Windshield Wipers?
