torque converter
Old Nov 30, 2010 | 07:45 AM
grizz 454's Avatar
grizz 454
torque converter
new question. i was wondering if i disabled my converter from locking up and drive it like that, would it be tearing something up. and what about how would i go about fixing it so it wouldnt lock at all for a test drive. if it doesnt change anything ( my problem ) then i,ll hook it back up. maybe cut a wire on it somewhere 1990 f350 7.3
Old Nov 30, 2010 | 12:16 PM
grizz 454's Avatar
grizz 454
ok so i was uptown stopped in a transmission shop, let em drive my truck, he said its normal. thats the way its programed to shift from factory. only option i had was to put something on her to change when the torque converter locks up. a tuner or something like that.so anybody know of a good one that an everyday mark like myself could install?
Old Nov 30, 2010 | 01:22 PM
fellro86's Avatar
fellro86
You could also set up a pressure switch that disconnects the signal until you want it to engage, depending upon what it is you wish to achieve.
Old Nov 30, 2010 | 01:29 PM
grizz 454's Avatar
grizz 454
thanks. know where i can get some directions to do this?
Old Nov 30, 2010 | 02:17 PM
fellro86's Avatar
fellro86
There are articles about it on the net, seen many that were referring to doing it on Dodges, but the same idea applies. Main thing is knowing what governor pressure you want it to cut in at, and then hook it up in the governor pressure tap. Governor pressure corresponds to a driveshaft speed, which then relates to ground speed. I had looked up some switches to do this to the Cummins trans when it was automatic...
SANDDEMON08
6.4L Power Stroke Diesel
Dec 1, 2013 10:57 AM
Christopher Rohland
Aug 31, 2013 06:30 AM
mackdog
1983 - 2012 Ranger & B-Series
Jul 14, 2011 12:34 AM
rallynutdon
May 5, 2011 09:18 AM
rpcarlson
Dec 3, 2005 01:52 PM
