2000 EX
Old Nov 30, 2010 | 12:27 AM
speed 318's Avatar
speed 318
2000 EX
HI EVERY ONE... IM NEW TO THIS FORUM AND I NEED SOME HELP...IM PLANNING TO PURCHASE 2000 EXCURSION I NEED SOME ADVISE....WHAT EXACTLY YEAR MODEL IS THE SOLID AXLE IN FRONT? AND HOW MANY INCHES OF LIFT IN ORDER TO FIT 40 INCHES TIRE...THANKS...
Old Nov 30, 2010 | 06:45 AM
blackx psd's Avatar
blackx psd
If it is a 4wd it is a solid front end. I am not sure how big of a lift you will need but it's going to be a big one to fit 40's. Might as well plan on regearing as well. Good luck!
Old Dec 1, 2010 | 05:35 AM
locknload223's Avatar
locknload223
The front axle is a Dana 50. If you're going with 40" tires and plan on hard off road use, you can always swap out to a Dana 60 front axle from an F350. You're probably looking at 8" of lift depending on your intended use of the truck.
Old Dec 5, 2010 | 01:16 AM
speed 318's Avatar
speed 318
EX 2000
THANKS FOR THE INFO GUYS....BTW HOW ABOUT THE GEARING AND ANY ISSUE ON THE DRIVE SHAFT IF I GO ON THE 8 INCHES LIFT........
Old Dec 5, 2010 | 01:22 AM
speed 318's Avatar
speed 318
EX 2000
THANKS FOR THE INFO GUYS.... BTW ANY ISSUE ON THE DRIVE SHAFT (CASTER CORRECTION) OR SYSTEM IF I GO WITH THE 8 INCHES LIFT...THANKS
Old Dec 5, 2010 | 01:26 AM
speed 318's Avatar
speed 318
EX 2000
IS DANA 50 CANNOT HANDLE 40'S TIRE ? DRIVE MOSTLY ON THE HIGHWAY...AND WHAT IS THE BEST GEAR RATIO?..THANKS
ifrythings
Oct 27, 2016 11:39 PM
Vijay
Sep 12, 2016 09:02 AM
Melendez7.3
Jan 5, 2015 07:13 PM
SUPERDUTYOKIE
Jan 18, 2014 07:21 AM
Pwilson32
1997 - 2003 F150
Sep 24, 2012 09:59 PM
