Squeak Prevention Tips?
Old Nov 29, 2010 | 06:44 PM
turnrjr's Avatar
turnrjr
The chassis is done, the 223 is in it and it runs well. Over the weekend I was looking at the bunch of body and panel parts that are the next part of this project. There is a lot of cleaning, straightening and patching needed before assembly but I was wondering if anything is put between bolted panels to keep them from squeaking. I know about the welting at fenders. What about other bolted panels like the air deflector panels and inner fenders? I was thinking something like the fabric type electrical tape run along the contact face where the bolts go. What have you guys done?
Old Nov 29, 2010 | 07:00 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
I'd say that cloth-type tape would hold moisture.As far as rubber welting,not sure if it is necessary or desirable.
Old Nov 29, 2010 | 07:33 PM
56panelford's Avatar
56panelford
I'll be using a seam sealer when I do final assembly of the front sheet metal, it's the kind that stays relatively soft to keep dust and moisture out.
Old Nov 29, 2010 | 07:41 PM
spurredon's Avatar
spurredon
The best way to cut down on squeaking and squawking is to leave the passenger home! HaHa!
Old Nov 29, 2010 | 08:20 PM
cmoritz's Avatar
cmoritz
I asked myself this question over the summer before putting the front clip on and my conclusion was..everywhere there was rubber between panels, there was rust..and in some cases ALOT of repair work to remedy. I decided to use the fender to cowl welts anyway, if only to help protect the paint while fitting. Since there was no evidence of heavy rust anywhere else, I decided against using it elsewhere..I just tightened things down ,metal to metal (paint to paint).
I also agree with spurredon..
Old Nov 29, 2010 | 08:30 PM
firstrider's Avatar
firstrider
Use some type of fender welt between panels where their is metal to metal contact .Rear fenders , front fenders to front side of cab , all front sheet metal panels .
Old Nov 29, 2010 | 08:52 PM
Julies Cool F1's Avatar
Julies Cool F1
I use ear plugs!
Old Nov 29, 2010 | 09:45 PM
abe's Avatar
abe
Its not really an old truck if it doesn't squeak!!!
Old Nov 29, 2010 | 10:25 PM
cwordsmith's Avatar
cwordsmith
anti squeeks
I bought webbing from LMC part No. 49-9305 and intend to use a sealer like my PO had used on the rear fenders.
Slightly off thread but do you intend to spray all the parts before assembly like Sam D. did or afterwards.? My PO had sprayed the areas of contact on the rear fenders just to make sure the color was in there.
Chris
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden"><input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Nov 30, 2010 | 09:56 AM
petey shoes's Avatar
petey shoes
i used the plastic welt between all my panels. no squeaks and can't hold water. always cut it longer than you want so you can hide that unsitely hollow end. they have been on my truck for 20 years now, and clean up real well.
