1978 - 1996 Big Bronco
Broken windshield washer
Old Mar 1, 2003 | 04:33 PM
dassmoof's Avatar
dassmoof
The stupid thing wont squirt. I don't know if theres a motor or something that burned out or what. Any ideas?
Old Mar 1, 2003 | 05:43 PM
mrwizard's Avatar
mrwizard
There is a motor. Does it make any sound like it's trying to pump? If it sounds like it's trying to work, your nozzles could be clogged.
Old Mar 1, 2003 | 06:32 PM
dassmoof's Avatar
dassmoof
Nope, no sounds at all. I push the button and it doesn't do anything. Any ideas on where it's located? My Bronco is an '86
Old Mar 1, 2003 | 07:31 PM
Boss_358's Avatar
Boss_358
The washer pump motor is at the bottom of the tank. It should have a plug going to it. There is a steel ring that you will have to dig off with a screwdriver or pull off with a needle nose pliers. Then you can pull the pump out with a pliers. A new pump should be less than $20 at the parts store.
Old Mar 1, 2003 | 10:34 PM
bronco351's Avatar
bronco351
I have the same problem with my windshield washer. My windshield washer's motor works, it makes a loud noise like it's trying to pump. The thing is when something does come out it's coming out as thick as dish soap!!! What do I do to fix it. The stuff in the tank is blue and it's not thick at all!!
Old Mar 1, 2003 | 11:30 PM
steve83's Avatar
steve83
bronco351
Take the hose loose from the bottom of the tank and also at the spray nozzle on the wiper valance, then run water from a garden hose thru it until it clears out. If it won't flow, trace it to see if there's a kink or check valve in it. It runs inside the fender & across the hood hinge.
