OLD Burnt UVCH...
Old Nov 29, 2010 | 05:05 AM
mq1shooter's Avatar
mq1shooter
OLD Burnt UVCH...
Does anybody have a donor old, burnt non-usable UVCH? I need a injector connector off one to replace my IPR connector.
Saw a post that the Inj. connector on a UVCH is the same.
Any help appreciated.
Old Nov 29, 2010 | 08:27 AM
Talyn's Avatar
Talyn
They dont look the same to me....
Old Nov 29, 2010 | 08:35 AM
Talyn's Avatar
Talyn
Old Nov 29, 2010 | 04:08 PM
mq1shooter's Avatar
mq1shooter
Myth Busted...
well , by looking at your pic's...that Myth is Busted...
as I have yet to change out my UVCH's I was at a disadvantage...
Well my search goes on, hate like hell to replace the whole harness....
Old Nov 29, 2010 | 04:27 PM
Talyn's Avatar
Talyn
What is wrong with yours? The connector go bad?
It's pretty simple harness.
Old Nov 29, 2010 | 04:49 PM
Action4478's Avatar
Action4478
Mine was real bad . I took it out & spliced in some new wire, soldered the connectors in the weather pack part , heat shrink tube & put it back in ...Been a couple years since the repair ...
You may be able to take it apart & put heat shrink tube on the wires where the insulation is missing ...
Old Nov 29, 2010 | 04:51 PM
mq1shooter's Avatar
mq1shooter
Yep, due to age, Diesel fuel, the connector and the water tight seal is mush....I had a miss situation and I pulled over and check all things electrical and wiggled the IPR harness and Killed the engine. Bad Connector...IPR new. Scanned with AE and all other data looked normal.
Old Nov 29, 2010 | 04:54 PM
mq1shooter's Avatar
mq1shooter
Yes, that may be the best option...
...Wiggle a wire harness and kill the engine...but it throws no code or CEL..on the IPR. Guess that just isn't supported or has a sensor to throw? on the AE? Just rammblin here!
Old Nov 29, 2010 | 05:38 PM
brooksbronco17's Avatar
brooksbronco17
The second pic talyn posted looks the same to me.
found this on ebay. not cheap but looks like it's got everything needed.
Ford Diesel 6.0 & 7.3 IPR REGULATOR WIRE REPAIR KIT - eBay (item 190456551721 end time Dec-13-10 06:48:22 PST)
Old Nov 29, 2010 | 05:53 PM
Action4478's Avatar
Action4478
We have been told for years the plug is the same on an injector
Old Nov 29, 2010 | 05:56 PM
mq1shooter's Avatar
mq1shooter
True...and looking at the eBay item, they seem to look close?
My current connector did NOT have the bale....
Old Nov 29, 2010 | 05:58 PM
mq1shooter's Avatar
mq1shooter
....I am all about the "recycling Thing" ...makes my wallet happier Too, and I get that "done it myself" feeling!
Old Nov 29, 2010 | 06:53 PM
Action4478's Avatar
Action4478
Old Nov 29, 2010 | 06:54 PM
Action4478's Avatar
Action4478
It should .....Look in the valley of death .....
Old Nov 30, 2010 | 09:00 AM
Talyn's Avatar
Talyn
The actual plug itself is the same, sorta.
As you can see on my IPR connector, I've repaired mine with heat shrink as well.
If they only did it like that at the factory. haha.
The actual plug is maybe the same, or damn close, but as you can see, the clips and the back of the plug is different.
So I guess if you want to zip tie your IPR connector on, thats cool.
