Sponsored by: Real Truck
Battery keeps going dead
Old Dec 1, 2010 | 06:47 AM
CA Diesel Guy's Avatar
CA Diesel Guy
Arent the SD trucks set up so One battery is mainly for starting the truck and the other battery is for accessories??
Old Dec 3, 2010 | 01:18 AM
matt10461's Avatar
matt10461
Well my 2004 F-250 Super Duty only came with one battery. At least that's all I can see when I lift the hood. LOL!!!
Old Dec 3, 2010 | 01:25 AM
orng1's Avatar
orng1
The diesel have two, they are linked because I just killed both wednesday. I still haven't taken them out to charge them.
Old Dec 3, 2010 | 05:52 AM
CA Diesel Guy
Ya sorry I was talking about the Diesel SD sorry ORNG1
Old Dec 3, 2010 | 10:24 AM
redford's Avatar
redford
FTE Leadership Emeritus
You guys tend to over think the charging system in these trucks. There are 3 components.
First is the alternator. It makes power.
Second, the battery or batteries. They store power.
Third, the cables that connect them all together. They transfer power.
If the battery is dead, it is usually one of four things.
First, the alternator (or alternators) is not producing enough power to run the truck AND put power in the battery.
Second, the battery is old and cold, so it is not storing the power the alternator makes.
Third, the cables are not moving the power from the alternator to the battery.
Fourth, something is draining the battery while the truck is off. Some current will flow when off, usually under 2 amps depending on your accessories. When phantom current is suspected, it is usually a bad battery that is the culprit.
Old Dec 3, 2010 | 10:58 PM
matt10461's Avatar
matt10461
OK. Got in my truck this am and damn, heard all that clacking under the dash again. Popped the hood, pulled the dead battery, checked it, charged it, load tested it and now the meter tells me that its bad. Kinda sucks because the battery is only 6 months old! I wonder just how good these Duralasts really are? Not too good in my opinion.
Old Dec 4, 2010 | 06:39 AM
nfntruth's Avatar
nfntruth
I run optima yellow tops. They can be deep discharged multiple times, and have a very low fail rate. All three of my trucks are optima powered, pricey, but I have NEVER had a problem. One of the optimas started in my 06 explorer and has been handed down through 3 other trucks before finally resting in my Isuzu. I know they are pricey, especially for two, but peace of mind is worth it.
Old Dec 4, 2010 | 09:18 AM
BareBones's Avatar
BareBones
Now that's interesting about subsequent load tests yielding different results. A year or two ago I had a failure of the original equipment battery in my 350, and initially it passed a load test. But when the problem recurred a couple of weeks/months later, it flunked the load test.
Sounds like maybe there's some window where marginal batteries will hold a decent CCA charge, just not overnight......
Old Dec 4, 2010 | 09:26 AM
carltonwebb's Avatar
carltonwebb
@ 6 months old, it should still be covered by warranty.
Old Dec 4, 2010 | 01:16 PM
Bobcat7's Avatar
Bobcat7
I remember having the ol' ladys exploder on the beach and the lights would work but the starter would not crank. The sheriff came by to kick us out of the twp park and we got him to let us use the jumper cables in his trunk. No spark or drain/ pull on his system ... but still no crank. The lights would go out when trying to start and finally wouldn't come back on.
It was a crack somewhere in the conductors of the battery that would allow enouogh juice to flow to light the lights but would fry itself apart from the load of trying to crank the starter.
Hard to figure something like that out at 10pm, on the beach, empty cooler, etc - you get the pic!
Old Dec 5, 2010 | 12:55 AM
matt10461's Avatar
matt10461
Actually to clarify what I did, I charged the battery and load tested it the load test said the battery condition was good but when releasing the load test button, the meter said to re-charge the battery, sooooo, I fast charged it for about 20 min. did another load test and the meter said the battery condition is good but to re-charge again. Obviously the battery is'nt holding the charge. Thank you for all you're in put.
ccjohnse
6.7L Power Stroke Diesel
May 15, 2017 10:15 AM
preppypyro
6.4L Power Stroke Diesel
Mar 12, 2017 09:59 PM
Smirks90
13
Nov 1, 2014 05:11 PM
19-F250-78
15
Nov 4, 2012 07:57 AM
larryweston
Modular V8 (4.6L, 5.4L)
Dec 19, 2010 09:22 AM
