1994 Ford F150 4.9L Carberator Conversion
Welcome to FTE! You should start your own thread and post a picture. Even as a newb I think you can post a pic.
I'll second that. I remember feeling like a cave man poking it with a stick. Now as you say; why can't the lawnmower and weed eater have EFI. I'll throw in another couple of things, today's gas is much more EFI friendly than carb friendly. I finally sold my 79 F350, tired of yearly rebuilds on the carb, bought a 96 4.9 and love it. The other thing is the 300 I6 never really had good fuel distribution, it gained the most of the existing engines when EFI was added and it became the 4.9. The V8s had good fuel distribution to begin with, so gained less from the transition. I suppose a modern 4bbl manifold would be less of a problem, but still, this is the golden age, and this from a guy who was considered a pretty good carburetor man at one time.
I want to get rid of fords silly attempt at EFI and throw a holly sniper on my 4.9. Evey time i find an issue and fix it it runs worse. These EFI systems are archaic and should be done away with. The computer is to simple to tel you anything specific and just complicated enough to be hard to diagnose.
The following users liked this post:
It doesn't run right now... because the efi is not a very good system.
I'm not sure what all is involved with the Holy Sniper EFI, but I'm very happy with my PimpX ECU by Stinger Performance. It is an implementation of MegaSquirt that is setup to plug into your factory wiring.
I'm using it to power a 5.8L, but you could run any engine with it.
Here's a link to my PimpX install thread if you're interested in reading about it...
https://www.ford-trucks.com/forums/1...x-install.html
I have some experience with the Holley Sniper EFI, mainly on SBC engines and it is not as reliable as the OEM systems. It also is a throttle body style of system which would be a downgrade from the port injected EECIV. You may want to consider the Holley Terminator X or a MegaSquirt system which would allow you to retain factory manifolds, Nonetheless, you will have to learn how to tune if you are contemplating cams or forced induction.
Good luck!
And the closed loop tuning off of just the O2s is slow and clunky, there is a reason nobody uses it for performance applications.
#28
Im looking to convert my truck to carberation to eliminate all of the OBD1 and Emissions bull**** that I cant stand working on. I heard that my truck needs its EGR valve otherwise it will burn the valves. Is this true?
What CFM carb would be recomended for this motor also?
I love the 85 Mustang dual snorkel air cleaner
#29
#30
This is why I'm not a huge fan of this forum...2MNY @$$HLES...yes with all the changes including the Op intake,4bbl,MSD ignition,coil,and distributor,air cleaner,and last but not least the Holley fuel pressure regulator. On EFI I had to turn off the A/C to pull a hill...now I gain speed on the same hill with the A/C running...so......please don't discourage from swapping to old school....its far more adjustable and trustworthy... I only with the E4OD didn't need that stupid throttle sensor to shift...oh...and if I behave myself and stay out of the 4BBL,I can get 18 mpg on 89 octane...WITH E90...DO THAT WITH 94 EFI
