Tilt steering problems again
Old Nov 28, 2010 | 05:50 PM
mdacton's Avatar
mdacton
keeps eating up the bearings in the upper column recently replace everything in there the race the support the bearing all of that with new parts and it did the same thing again cant figure out why.
Its a 97 dually f350. Has no airbag/clock spring either just a regulat tilt column
Old Nov 29, 2010 | 01:24 AM
pnp522's Avatar
pnp522
Did you replace the shaft and the large bearing?
Old Nov 29, 2010 | 01:26 AM
pnp522's Avatar
pnp522
Asking because I just finished mine. The shaft was chewed up both on the small upper bearing and the one down inside the column.
Old Nov 29, 2010 | 01:25 PM
mdacton's Avatar
mdacton
I only did the upper bearing
