cold start issue
Old Nov 28, 2010 | 01:01 PM
dangolbadangdang's Avatar
dangolbadangdang
cold start issue
i have a 1980 ford f150 351 with a holley 4bbl 500 cfm carb, ive recently been having an issue starting it when its real cold(35F or below) it just cranks but wont turn over. i recently replaced the coil and a few other ignition parts, and i also adjusted the choke on it but still nothing...any ideas would be greatly appreciated.
thanks
dave
Old Nov 28, 2010 | 01:55 PM
Franklin2's Avatar
Franklin2
I believe in 80 you have a solenoid with one small terminal correct? Even though I can't find out whether it does or not by the diagrams I have.
Just as a experiment, make up a jumper wire and run it from the battery + terminal to the coil + terminal. On a cold morning hook the coil + directly to the battery and see if it makes any difference. If it doesn't fine, it's not the resistor bypass circuit. If it does make a difference, you may need to look into that a little bit closer. By the way after it starts, take the jumper wire off, you can't leave it on all the time.
If this is not the original engine or someone has been doing some "wiring", you may have lost the resistor bypass feature.
Old Nov 28, 2010 | 06:59 PM
Wicked Endings's Avatar
Wicked Endings
You are driving a FORD!
Cold beasts, these Fords.
But no, Franklin2 sounds like he knows what he's doing. I, personally, on cold mornings just give it a little gas, shoot a little starter fluid in the carb, and turn it.
Starts up, usually.
Old Nov 29, 2010 | 09:04 AM
Sw1tchfoot's Avatar
Sw1tchfoot
Starts up, usually.
I must be doing something right because I pump the gas two times and hit the key and mine starts right up
Old Nov 29, 2010 | 10:18 AM
LARIAT 85's Avatar
LARIAT 85
As long as I drive mine at least every few days, mine will start up the first time with only one pump of the gas.
Old Nov 29, 2010 | 05:43 PM
Old Hickory's Avatar
Old Hickory
My 1981 starts good when it is cold. Like Lariat 85 said, one pump if I drive it much but
two pumps if it has sat much.
