Trans doesn't like to shift when cold.
Old Nov 28, 2010 | 10:11 AM
FLfireBUG248's Avatar
FLfireBUG248
My transmission doesn't like to shift when cold. It goes into gear but goes into higher rpms before shifting. This goes on for about 3 miles. It's avoided if I let it warm up in the driveway for about 10-15 min. any ideas? what can i do? Also, I am hearing alot about an OASIS report, dont know what it is though...
Old Nov 28, 2010 | 12:17 PM
texans's Avatar
texans
can't be of much help on the trans issue you have, but an OASIS report you get from the dealer. It tell what all warrenty work has ever been done by the dealer to your truck. Good info to get when looking at buying a used truck.
Old Nov 28, 2010 | 12:25 PM
Jigger2020's Avatar
Jigger2020
I'm pretty sure you are supposed to let your truck warm up, how many K's on it, is it low on fluid? Gigger
Old Nov 28, 2010 | 12:31 PM
69cj's Avatar
69cj
When was the last time the tranny was serviced?? Every 30,000 miles with ext. filter and mercon SP or LV fluid only. You shouldn't have to let the truck warm up for 10 or 15 mins.
Old Nov 28, 2010 | 12:45 PM
FLfireBUG248
just bought the truck the beginning of OCT/10. So I dont know the last maintenance. It's a 2006 f-250 6.0 CC FX4 Lariat with 125,000mi. Fluids are all good, no leaks.
Old Nov 28, 2010 | 12:51 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
It wouldn't be a bad idea to change all your filters and fluids just so you know where you stand. That will also give you reference point for future maintenance intervals.
Old Nov 28, 2010 | 01:30 PM
sammy77's Avatar
sammy77
The Torqshift's nature tends to shift a little late and hard. However this only occurs when cold. If this is happening more often you'll have to dig deeper on it. Try a flush first with an external filter change
Old Nov 28, 2010 | 01:51 PM
69cj's Avatar
69cj
And make sure that you use all OEM filters. The 6.0 doesn't like a/m's.
Old Nov 28, 2010 | 02:12 PM
Jigger2020's Avatar
Jigger2020
69CJ your info is right on but it's hard to put faith into someone who didn't spell Lariat correct in his siggy, Gigger
Old Nov 28, 2010 | 02:20 PM
ljutic ss's Avatar
ljutic ss
Just how cold does it get in North Fort Myers?
Old Nov 28, 2010 | 03:39 PM
FLfireBUG248
not that cold at all. I am just talking after its been sitting overnight, 10 or so hours. Right now our lows are in the 60's. Not real cold for most people reading this. its pretty comfortable right now. sorry bout that. I am new to threading, still trying to pick up on the lingo
Old Nov 28, 2010 | 03:51 PM
OHSIX6OH's Avatar
OHSIX6OH
I think its just the nature of the beast due to the internal T-stat in the tranny. My 06 will shift out a bit later when cold with a firmer upshift ,All is normal after a bit of warm up. Allways has done this.
Old Nov 28, 2010 | 04:02 PM
FLfireBUG248
yeh, it runs great after it runs a little. I just hate having to let it "warm up" every day. But I foresee a trip to the dealer here in the future for a fluids change. Awesome response for my first post, thank you all. I am sure I will be back for more help.
Old Nov 28, 2010 | 04:26 PM
ljutic ss's Avatar
ljutic ss
You might be better off if you cut out the excessive idling in the driveway, the only way to warm the trans is to drive the truck. Excessive idling leads to fuel dilution, EGR issues and more. As someone already posted that you should replace all fluids and filters, motor oil, trans oil, transfer oil, differential oils, power steering fluid, brake fluid and engine coolant, Air filter. Make sure the fuel filters (2) are changed using only OEM filters and the required fluids. This is the only way to ensure peace of mind and a mileage to start future service. All this service I mentioned is a little pricey, but it's much less expensive compared to repair's due to service neglect.
Old Nov 28, 2010 | 04:46 PM
FLfireBUG248
I will do that, thank you. didn't know that about the idling. didnt really think it would hurt anything being done in such short time periods.
