Turbo problems?
Old Nov 28, 2010 | 08:05 AM
gdorst's Avatar
gdorst
Unhappy Turbo problems?
I have a 1997 F-250, 7.3 with 205,000 miles. When pulling a load, small or large, the turbo gets up to 900 degrees and there is a thumping that can be heard and felt to the driver. All other parameters are normal. HELP!
Old Nov 28, 2010 | 09:50 AM
jg96powerstroker's Avatar
jg96powerstroker
kinda need more info on your truck mods and all are you all stock or what, welcome to fte
Old Nov 28, 2010 | 09:54 AM
cowmilker08's Avatar
cowmilker08
Check all your universal joints. They will often cause vibrations and shutters before they blow out.
900 degrees on the turbo is nothing to worry about.
Old Nov 28, 2010 | 10:01 AM
fordpride's Avatar
fordpride
where is your pyro probe at manifold or downpipe
Old Nov 28, 2010 | 11:20 AM
gdorst's Avatar
gdorst
Turbo Problems
All stock, no mods.
Thanks
Old Nov 28, 2010 | 11:24 AM
gdorst's Avatar
gdorst
Probe on the downpipe, u-joints are OK.
Old Nov 28, 2010 | 11:26 AM
gdorst's Avatar
gdorst
The thumping sound comes from behind the passenger footwell area.
Old Nov 28, 2010 | 12:52 PM
427 fordman's Avatar
427 fordman
Probe should be on the manifold, not the downpipe. You won't get accurate temps on the downpipe. It reads 2-300 degrees too cool there. Magic number is 1200 though, don't want to be over that for very long.
WAG, is the downpipe loose, hitting on the body?
Old Nov 28, 2010 | 07:40 PM
59JEEPSTANG's Avatar
59JEEPSTANG
I had a simalar issue this summer but I have an aftermarket down pipe. Turned out that under load (towing Jeep on trailer with pickup camper on back about 16k lbs overall) the down pipe was just touching enough to make me think something bad was about to happen. I took a pry bar and made a little more clearance (also make sure insulation is not touching) and all is good again. If you do in fact still have your stock down pipe this is more than likely not your issue.
Paul
Old Nov 29, 2010 | 01:03 AM
cowmilker08
X2 above. A common problem that needs some tweaking.
Old Nov 29, 2010 | 12:44 PM
Major Marvin's Avatar
Major Marvin
I think I may have the same deal going on. Sounds like something is thumping around on the right side of the dash while driving the rougher roads.
Old Nov 29, 2010 | 06:27 PM
FARM69's Avatar
FARM69
Yep, I have the same problem as well with my custom pipe. Just get a pry bar in there and work it a little bit.
When that pipe hits the tranny or the firewall it will sound like what you described.
