cleaning injectors
Old Nov 28, 2010 | 02:33 AM
7.3bo-ti-etr's Avatar
7.3bo-ti-etr
cleaning injectors
Going to be doing this tomorrow. So when I get to the auto parts store what's going to be the best stuff to use. O and I'm just adding it to the fuel bowl. Thanks
Old Nov 28, 2010 | 02:42 AM
orng1's Avatar
orng1
Stanadyne works good, diesel klein works too.
Old Nov 28, 2010 | 03:20 AM
7.3bo-ti-etr
Ok cause I'm just going to drain the fuel bowl and the fill it up with what I buy
Old Nov 28, 2010 | 03:30 AM
orng1's Avatar
orng1
Stanadyne is hard to find but works good. See if you can get a bottle.
Old Nov 28, 2010 | 08:40 AM
damicofuel's Avatar
damicofuel
Powerservice 911 to fuel tank, clean them with time. I wouldnt want to use full strength, too many o-rings and seals to bet buggered up!
Old Nov 28, 2010 | 08:58 AM
ff1210's Avatar
ff1210
migtey i think is the name of the stuff i used you pour it in the tank. and you take the can of cleaner that comes with the kit you take the intake loss and run the tube up inside the intake and spray the hole can and that stuff cleans all your sensors. The stuff comes out of the can at -12 deg. I could tell a difference in about 50 miles. My truck had 126000 on it so im sure it needed it.
Old Nov 28, 2010 | 09:01 AM
ff1210's Avatar
ff1210
sorry it cost me 49.99 at the local tire store.
Old Nov 29, 2010 | 03:17 PM
aklim's Avatar
aklim
Just take the injectors out and send them away to be cleaned if it has the mileage on it. That or leave it alone and not try the snake oils.
Old Nov 29, 2010 | 03:19 PM
Muktown's Avatar
Muktown
Drain the fuel bowl and fill it up with atf. Then put a little in the take for the next few tanks
