73, F100, 302 mild cam, C4 tranny. The tranny will not shift from 2nd to third.
The unit was been shifting a little harder than normal, as the weather cooled it became worse and took muck longer to shift. Now it with only shift from 1st to 2nd but not into 3rd. I cannot shift in to 3rd manually as well.
Replaced the modulator, did a finger check of vacuum, still the same issue.
