Sponsored by: Kumho
Brake line help
Old Nov 27, 2010 | 09:24 AM
USMC35thSS's Avatar
USMC35thSS
Brake line help
Does anyone know where I could get a hard brake line kit for a 95 F150 4x4? I found a kit that was for an 87-90.... did the lines change from 90 to 95?
Thanks
Old Nov 27, 2010 | 03:24 PM
Turx's Avatar
Turx
NPD sells complete kits for around $150/Steel and $175/ Stainless Steel. A few others I've dealt with are Inline Tube, Bronco Graveyard and LMC. I would think the "earlier" years would be pretty close to the 95, but there might be slight differences. I'm sure others with better knowledge here will chime in. If your up to it, you can also buy the line in different lengths that are already flared with fittings or buy a roll and cut to the length you need, slip on a fitting and flare the ends. Which is much cheaper and really not that hard. The difference in price would add a "Flaring Tool" and "Tubing Bender" to your tool box and still be a bit cheaper.
Old Nov 27, 2010 | 04:52 PM
USMC35thSS's Avatar
USMC35thSS
Thanks. I will see what those places can do for me.
