Gringing/rubbing when turning
Old Mar 1, 2003 | 08:29 AM
grey169's Avatar
grey169
I have a ' 97 expy and when I turn around a corner I hear what sounds like tire rub on the frame/suspension. There is no tire rub any where from what I can see. It has been getting worse also. I read earlier where someone on the list had posted that they did a fluid change on the front suspesion. All this would entail is just draining out the front differential and refilling it? Is there more to it? Does this hold 80/90W oil? Any suggestions before I start on this project?
Old Mar 1, 2003 | 10:23 AM
Racerguy's Avatar
Racerguy
Can you tell if the noise is coming from the front or the back?
I'm wondering if you have chattering limited slip clutches in the rear diff.
To change the oil in the front diff you just remove the drain plug to drain the oil then fill it with 80W90 through the fill plug.
Old Mar 1, 2003 | 05:27 PM
grey169's Avatar
grey169
The noise is coming from the front right wheel. It seems to be most predominant when the vehicle is turing to the left. On right hand turns I hardly notice it. Today when I was driving around it seemed less. Today has been unusally warm (almost 30 degrees warmer then the last few months). I don' know if that means anything or not. I hope that this helps narrows down the problem. How much fluid do I need for this?
Old Mar 1, 2003 | 08:56 PM
Racerguy's Avatar
Racerguy
Sounds to me like your right front wheel bearings are going. Usually the r/f will be loud when turning left and vice versa.
The wheel bearings arent replaceable seperately.....you have to replace the whole hub/bearing assembly.
The front diff holds about 2 quarts of oil.
Old Mar 4, 2003 | 02:54 PM
jonjamky's Avatar
jonjamky
might be the pitman arm .trying using a needle valve on your grease gun and squirt some ggrease through the rubber poiece on the pitman arm.same thing happened to my 97
Old Mar 4, 2003 | 08:22 PM
Paxcam's Avatar
Paxcam
Does it grind/rub when you brake? Or only when you turn left?
Old Mar 7, 2003 | 03:46 AM
User 9823's Avatar
User 9823
Had to replace the pitman arm (well, got the dealer too) on my expy as the sound was frickin awful.
farva66
Aug 26, 2014 06:36 PM
hines182
Dec 6, 2006 08:02 PM
just_brian
Jan 6, 2004 08:28 PM
fordtrck302
Offroad & 4x4
Jan 11, 2002 05:55 AM
calyx
Jun 15, 2000 08:20 AM
