Speedo removal
Old Nov 25, 2010 | 09:19 AM
00Boss's Avatar
00Boss
Speedo removal
Iv been searchin and searchin but I cant find out how to remove the cable from the speedo. I was goin to pull my gauge cluster yesterday and got hung up , help please
Old Nov 25, 2010 | 09:29 AM
Franklin2's Avatar
Franklin2
There is a plastic piece where the cable connects. Push this piece to one side, and it will come off. If you have a lot of pressure on the cable, it might be stubborn, so try to relieve that as much as possible, which is sort of hard to do when you need room for your hand, but it will finally come off if you push the retainer sideways the correct direction.
Old Nov 25, 2010 | 10:08 AM
00Boss's Avatar
00Boss
Thanks I got it torn apart just playin with it now so thats alot of help
Edit: I got it to spin but thats all i got is there sweet spot or does it unthread like a screw or is mine just being really stubborn and needs a little more elbow grease
Old Nov 25, 2010 | 10:48 AM
ctubutis's Avatar
ctubutis
Just squeeze the white plastic and pull it straight off.
Old Nov 25, 2010 | 10:56 AM
Rogue_Wulff's Avatar
Rogue_Wulff
On the plastic clip/end, there should be a tang that extends a little further than the rest of the way around, push in there. It should just slide off at that point.
00Boss's Avatar
00Boss
Ok ill try that thank you for the help
