4WD
Old Nov 24, 2010 | 07:26 PM
lechonera's Avatar
lechonera
4WD
I have a F250 6.0 4wd . The vacuum is leaking from the right side seals ??? and I figure I can leave the hubs lock all the time and just energize the electrical switch when I need 4wd and everthying should be fine ...Am I right ???
Thanks.
Old Nov 24, 2010 | 07:29 PM
dschuffert's Avatar
dschuffert
Yes, you are correct. However, you will put a lot of wear and tear on the front drive train with the hubs always locked. Not to mention you will reduce some of your fuel mileage.
