Glow-Plug Relay L.E.D. ?????
Old Nov 24, 2010 | 05:35 PM
Jager's Avatar
Jager
So, for those of you that have installed this LED do you now wait to start your truck until LED light goes out? Why? If you start the truck after the "wait to start" light goes out but the LED has not are you causeing damage to your glow-plugs?
Old Nov 24, 2010 | 05:40 PM
just another truck's Avatar
just another truck
No.. ON pobably both questions..
If it is 20 below and I dont give a .. oh wait.. if it is 20 below, and I know I have had problems with weak batteries, I will wait for the led to go out. If I am having no problems I will fire right up when the wait to start light goes out. I am trusting the computer to know how long it should take.
If ( hasnt happend yet ) my truck doesnt fire up, then I am going to be looking at my LED to see if it has indeed fired the GPR, or the GPR is closing.
For the most part, Our trucks should be able to fire to say-10 with out a MAJOR problem, but why try it when we have the GPR and GP's
Last edited by just another truck; Nov 24, 2010 at 05:42 PM. Reason: because I am drinking and not completeing my thoughts....
Old Nov 24, 2010 | 05:49 PM
malodin's Avatar
malodin
-10 without glow plugs? really? mine wont even start at 65 without glow plugs
Old Nov 24, 2010 | 05:52 PM
just another truck
I did say should right.. mine plays hard ball at 42*.. glad to hear I am not the only one
Old Nov 24, 2010 | 07:05 PM
BobbyDiesel71's Avatar
BobbyDiesel71
Are we all plugging our trucks in now???
I have yet to start, truck seems to be fine.
I have fresh batteries and alternator and newer glow plugs
I guess I should start...
Old Nov 24, 2010 | 07:19 PM
woodnthings's Avatar
woodnthings
No, That is how the system was designed. The PCM WTS light goes off much sooner than the GPR, especially when the temps are low. The glow plugs stay on to help the engine idle better on start-up.
The easy way to tell when the GPR shuts off is by your headlights for those that do not have an LED. When the GPR shuts-off the headlights will get noticeably brighter!
Old Nov 24, 2010 | 07:53 PM
schlepprock250's Avatar
schlepprock250
If it's very cold(between 20 and 30 degrees),I usually wait about 30 to 45 seconds before cranking,if the GP LED is still on it's just putting heat in the cylinders after starting,which is ok.
Old Nov 24, 2010 | 10:38 PM
spdmpo's Avatar
spdmpo
I pretty much use the light just so I know the GPR is working. And also it's useful for those times the engine has enough heat in it that the GPR doesn't activate but that WTS light still comes on, I know there's no need to WTS. In the summer time I don't ever WTS anymore, I just turn the key and go.
Old Nov 25, 2010 | 12:35 AM
orng1's Avatar
orng1
Am I the only one that can hear the relay buzzing?
Old Nov 25, 2010 | 12:43 AM
Ponyboychris's Avatar
Ponyboychris
Buzzing relay don't sound good to me. Even my old OEM's didn't buzz.
Old Nov 25, 2010 | 12:54 AM
orng1's Avatar
orng1
Maybe because it's an aftermarket one. My stock one stopped working shortly after.i got the truck.
Old Nov 25, 2010 | 08:39 AM
spdmpo's Avatar
spdmpo
Go get a Stancor on there and it won't buzz.
Old Nov 25, 2010 | 08:55 AM
allis327's Avatar
allis327
When I was kid I rember guys saying the glow plugs would burn off if they were on when the truck was running. Just figured it was another rreason to chew my butt.
Old Nov 25, 2010 | 10:32 AM
bigb56's Avatar
bigb56
Maybe they were talking about the 6 volt glow plugs which the early Fords used on a 12 volt system for faster glow time. If they stayed on for more than 10 or 15 seconds they could do some damage. VW Rabbits used the same ones.
On my old 6.9 I installed a glow plug indicator light for that reason, since I had heard of the glow plug controller sticking in the on position resulting in pieces of the glow plugs dropping off into the cylinders.
