electrical problem
Old Nov 24, 2010 | 08:12 AM
jk317's Avatar
jk317
electrical problem
I have a 97 f350 that keeps shorting out the #4 tail light fuse. It only shorts out when you drive the truck a little aggressively or at higher speeds. It does not short out if you drive slow or idle the truck. I have replaced the headlight switch and have checked each light attached to that fuse by disconnecting them one at a time and no luck. I've also checked the trailer harness with no luck. Any ideas ?
Old Nov 24, 2010 | 08:23 AM
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
Trailer harness connectors? Bare wire in rear fuel tank area of frame rail? Stop & Turn or parking lights? If Stop & Turn check the 3rd brake light extension wire (lt grre I think) that runs to the rear of the frame (factory wire incase a cab installed so truck remains "legal").
Old Nov 24, 2010 | 08:56 AM
jk317's Avatar
jk317
Parking lights, tail lights, and roof lights. Already checked the trailer harness. My buddy is looking at the wiring under the bed now.
Old Nov 24, 2010 | 09:12 AM
Brain's 97 Diesel
Factory roof lights? If yes pull the pass side kick panel off connector is behind it 2 wire connector w/ Blk & Brwn wires I think. See if loose or corroded from moisture or water leaks. take apart clean w/ tooth brush type wire brush apply di-electric grease & reassemble. do not tape connector up make corrosion from moisture occure faster.
Old Nov 24, 2010 | 02:13 PM
makomark's Avatar
makomark
That's also the fuse for the warning chime module. If that circuit has been modified, I'd check that, too.
