When I go to turn the motor over wether it's 10 degrees out for 70, the motor will start as normal then instantly sputter out.
Recently I have been starting the truck with a little throttle and just ultimately driving two footed (hate it), but I do not have much of a choice. At a stop light, the truck with drop down to 4-500 rpm and I am definitely not comfortable with that.
The motor is not missing at high or low RPMs.
I just put a new IAC on it today thinking that would help out atleast a little judging by past posts. I disconnected the battery while doing this also to possibly reset the computer, as stated in previous posts.
I also checked for vaccuum leaks and that came up negative.
You may try checking/cleaning the MAF (mass air flow sensor).
but i would think the code reader would find this.
other items you could check is fuel filter clog or fuel pressure.
I had this issue recently. Rather than throwing parts at it, I took to an independant mechanic. They ended up cleaning the throttle body, and injectors and putting on a new fuel filter (although they said a fuel filter would NOT cause the issue--> it was time for a new one). They said nothing else was wrong with it. It seemed to work, but now it idles a little high: 800-900rpm.
I will clean off the MAF sensor tomorrow while I am trying to get away from the in-laws, lol.
I don't really want to tear into my throttle body but it's sounding like I am gonna have to. I just put a new fuel filter in a couple months ago so I am guessing it's not that. But you never know with gas companies these days.
Cleaning the throttle body isn't a hard job at all bud, should be done every now and then just to keep it spiffy. I've done mine on my car twice, and once on the truck when I brought it home.
i had the same symptoms on a 4.0 OHC Explorer, it was a vacuum leak at the PCV elbow. i know it's a different engine but it still sounds like it could be a vacuum leak.
if you take starting fluid and spray it around the top of the engine while it's running, it will elevate the idle and help find the location if there is a vacuum leak.
I had this problem with an '01 5.4, I just sprayed out the idle air control valve with some throttle body spray and its all good now. You may do the same and fix it or replace it. Before you do, get it idling rough, tap the solenoid with a hammer and see if it levels out. Thats how you can check if it is bad.
If you can't find a vacuum leak it is likely your intake manifold gasket, just fixed my moms Escape with a rough idle by replacing the intake manifold gasket. But hers was silicone and the 5.4 uses a composite which is much more durable. But still could be bad and it would be a cheap fix.
Well here's the million dollar question of the day.. Is it possible for carb cleaner to freeze? I worked on my IAC and MAF sensor while it was a solid 20* outside. Made a three hour drive yesterday back to college and now the girl is running just like it should. Idles at 900ish as it should without any stalling at all.
The only thing I can possibly think of maybe I had some cleaner in the IAC still and it finally burnt it all out or just took a good running to get it loosened up.
