Offroad & 4x4
Repacking 6'' Procomps for 4'' + flex?
Old Nov 23, 2010 | 09:38 PM
ErrorS's Avatar
ErrorS
Just got a 6'' Procomp lift (springs only) for next to nothing for my Bronco. I already have a 4'' lift, a cheap Rancho one, with blocks in the rear.. I don't feel like going to 6'' just yet, the replacement tires would kill me, it's cold outside and the labor would kill me, it's too hard to get into and the girlfriend would kill me, etc.. too many reasons to list them all
I have to replace my rear axle before winter anyways, I'm going to hate putting the blocks back in when I do this. I think I'm just going to repack the Procomps to give me 4'' of lift, more flex than stock (I know they're stiff as is), to get that stupid block out from under my leafs.
Anyone have any advice so I don't have to do a million tests fits in the middle of winter in my driveway, with neighbors who already hate my Bronco because it's always under the wrench?
I've repacked leavs on my F150 before, it turned out really well, but it was summer and I had different neighbors, I spent a week testing different fits and combinations.
Anyways, should I remove the overload? center spring? top? multiple? heh, just give me a best guess, if I can get it acceptable in one try, i'd be very happy. My best guess would be to drop the overload spring, but I'm not sure it will make 2'' of difference by itself.
Old Nov 24, 2010 | 12:00 AM
ihateminimumwage's Avatar
ihateminimumwage
Pull the overload at least. Probably one more, but no way to know without test fitting.
For the time being, and if you're not against it, you could just do a shackle flip in the rear when you swap your axle. Only 8 rivets out, and 8 bolts in, and you get rid of the blocks until you want to deal with the 6" lift. Just a suggestion for a quick fix.
Old Nov 25, 2010 | 02:57 PM
alpha/omega's Avatar
alpha/omega
Id probably take out one of the longer middle springs first.
if its a 6 leaf pack take out the 3rd longest one.
BIGTRUCKBIGRV
6.7L Power Stroke Diesel
May 13, 2015 05:03 PM
jayjjcc
Mar 13, 2014 03:25 PM
jct81
Mar 8, 2014 02:06 PM
RMBC Freeride
Nov 25, 2013 03:11 PM
jlmotox
Mar 24, 2009 10:06 AM
